Question about GE JKP85 Electric Double Oven
GE double oven wall, JKP85B0A3BB
Microwave oven stop working. Everything seems to be working just fine (table turns, lights on, timer is fine, etc), but does not heat anymore. Very much appreciate if someone can recommend what to check, servicing parts that could be replaced, etc.
  • ivanrleon Oct 26, 2008
    Hello Hobarttech,
    Thanks for your promptly reply. I have tested the switches and the capacitor and they seem OK. Using my tester (Ideal 61-312), the diode appears open in both directions which is strange (diode is HVR-1X 3, SK 9014). Replacement the diode appears the right course of action, as I have no idea how to test the magnatron.
    Scholar:
  • 112 Answers
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
Microwave table does not turn
table motor needs to be replaced probably
Dec 07, 2013 | GE JKP86 Electric Double Oven
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
No heat and no rotate of the turn table. Everything else seems to be working as designed. This is the microwave
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Jan 16, 2011 | GE JKP85 Electric Double Oven
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | GE JTP85 Electric Double Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
Dec 01, 2008 | Ovens
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
GE JKP85 Electric Double Oven Logo
1,008 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
