Question about Intel BLKDH61WWB3 Blk 10pak Dh61ww Uatx Board Cpnt 1 Pcie 20 X16 Gbe Ddr31333 Motherboard
Im use Hd61ww with 2100 2nd generation processer its hanging. im not understand wat the problem . im changing hard disk , ram , im change different window7 64&32 bit, tell plz wat is problem . my Mail Id : cherrynetcafe2011@gmail.com
  • Intel Master
  • 27,725 Answers
Well it looks as though you have been moving plenty of computer parts and leads around double check that every lead has a secure seating including electrical extensions from motherboard to hard drive or even replace them with new ones
make sure all of your drives are working
computers need all power and data to travel through every working device and to have an end point to be able to work properly
make sure ram modules are clean and are securely seated and the ram sockets are clean
and cmos battery is securely seated
some motherboards cmos batteries are soldered in
make sure CPU has thermal paste and a dust free secure seating
hope this helps you
Posted on Feb 15, 2012
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
My sony vaio laptop is always hang 5 to 7 mins. but mouse pointer is still moving. all application im working are stuck a few minutes. what are the possible solution for this problem. i do reformat but...
Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
Mar 24, 2011 | Sony VAIO (PCWA-A200)
Prob with hard disk
IT IS NORMAL FOR THE HARD DRIVE TO BECOME VERY HOT WHILE WORKING. I WOULD SUGGEST YOU TO CHANGE YOUR RAM ONCE AND TRY. HANGING ISSUES ARE MOSTLY RELATED TO RAM.
Apr 10, 2010 | Samsung (SP0822N) 80 GB Hard Drive
I have a dell monitor that the power light is on but yet the screen is blank? Changed both vga cable & power with no effect?
Pls check that the your system is working or hang on the blank screen .For system check pls press the Num lock button on your keyboard its on/off or not.If your keyboard Num lock button is on/off then Problem with your Monitor might be might be EHT is faulty its better call vendor for repair.If system hanged on blank screen then problem with your RAM OR Hard disk or Operating system.
For Hard disk pls remove the power cable from Hard disk and on the system if not resolve then
Go for RAM,remove the RAM chip and re-installed another goods RAM ano on the system, If still blank screen then Problem with Operating System .Get it re-installed Operating system
Nov 16, 2009 | Dell E173FP 17" LCD Monitor
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Pc hangs up frequently
three things can contributeto the problem. (1) re-load the operating system (os) . 2. change and upgrade your ram. 3.change your prossessor.
Jun 05, 2008 | Computers & Internet
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Main board wont Power up
Hello.. i didn't quite understand if the problem occured after you changed the HDD and then became permanent. However the possible reasons are the same in any cases. Please note that a laptop mainboard can power on even without hard disks, ram , video card even without it's processor. That's because the motherboard itself "scans" for them AFTER it has been powered and the BIOS loaded (yep you can't start without BIOS)during POST (power on self test). If your motherboard can't power on now try the following. Remove the hard disk and the ram memory and try to power on. Of course expect beeps and errors from the BIOS, but if the mainboard powers and some LED's flash or do something, it isn't the motherboard who is faulty. Insert RAM and repeat the test. If it still works, then the hard disk you've installed is not compatible. IF however after removing both RAM and hardisk and the mainboard still doesn't power,surelly there is a problem in the DC charge/power on circuitry, that requires a specialised service to fix it. Hope this will be usefull and good luck.
Jan 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Intel BLKDH61WWB3 Blk 10pak Dh61ww Uatx Board Cpnt 1 Pcie 20 X16 Gbe Ddr31333 Motherboard Logo
145 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
