Question about TruTech T1300-D 13 inch TV
When I try to turn the volume up, it just goes right back down to 0 again?
Basically, the tv turns on at 0. I try to turn it up, but it just goes back down to 0 again, and I have no way of getting it to stay up. I tired turning the tv off and on again, but it didn't work ...
    Top Expert:
  • TruTech Master
  • 75,169 Answers
Hello
Check if the Vol DN button is at the front panel of the tV is strucked. This may happen to most of the tVs, as these are microswitces, which can be strucked to pressed stage, by a hard hit or so. It is best to replace all the microswitches inside the front panel. These switches are very cheap to buy and can be bought from most of the electronic spare part selling shops at your town. Desolder out one among them, keep it with you as a sample, when you go to buy new ones. You have to open your TV to acess these switches, can be located just behind the front panel of the TV.
Posted on Feb 15, 2012
When i turn the tv on the volum goes allyhe way up and when i turn it down the tv goes off
Try taking out the red cord and if that doesn't work then try the yellow and if that doesn't work then try the white.
Jan 28, 2016 | Hisense LHDN32V66AUS 32 in. LCD TV
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Why does the volume on my Magnavox TV immmediately go to 0 as soon as I turn it on, and then after I turn it up and take my hand off the volume button?
it would appear Volume down button is either shorted or something is constantly pushing on it forcing the volume to go down. You could try to press on the down button and see if it feels like it pushes back a little bit. The most common thing is that it gets sticky from grimy, sticky fingers, try to un-stick it using some alcohol on a cotton swab. Other that the only way to fix this is to take the tv apart and figure out the button problem that way!
Good Luck!
Rich Lilja
Apr 02, 2015 | Funai Magnavox 32md301b/f7 32-inch 720p Tv...
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
The volume on my tv goes down all by itself. I turn it up and it goes right back down to 0. With remote or manually, does the same thing. Also, can't turn tv off. have to unplug it to turn it off. Any...
Try taking the batteries out of the remote or taking it out of range from the tv. Then try turning the volume up on the Tv manually. If the volume continues to go down on its own then it is a problem with the tv set itself. If the problem stops with the remote out of the picture then it is a remote problem. As far as powering the unit off may be a similar issue. If there is an on/off button on the tv and it works to turn the power on but not off then it is a tv issue. If the remote turns the tv on but not off it may be something as simple as the wrong code being programmed into the remote(universal remote) or if it is the factory remote it may be an issue with that. You could try getting a new universal remote that works with your unit.
Jul 09, 2010 | Toshiba 32A33 32" TV
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Volume on tv set not right
Try unplugging the TV for 2 minutes then try again.
Feb 09, 2007 | Sharp 32C-240 32" TV
TruTech T1300-D 13 inch TV Logo
148 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
