Operating system even the usb keyboard doesn't help me
  • 86 Answers
Can i no wats the problem...with ur .usb keyboard
Posted on Oct 29, 2008
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Whenever i type d ]]]]]]]]]]]]]]]] gets typed automatically and now my sshif key i not working for some key.its so irritating and when im switchin ]]g on my system it goes on boot manager.please help...
Hi!
To determine wether it is a hardware (keyboard itself) or an OS problem, plug an external keyboard to your laptop (you didn't mention the manufacturer or model of your laptop, but even if it doesn't have a PS2 connector, it has almost for sure an USB connector to plug the keyboard in).
Now, if the external keyboard works OK it means no OS problem.
Hope it helped.
Bogdan
Aug 29, 2011 | Computers & Internet
I used a PS/2 Keyboard and one day it stopped working. And I found out that when it's installed even the mouse doesn't work, so I bought a new USB keyboard though I can't enter the BIOS with it...
Hi, you maybe just need a driver for the mainboard.
You can download here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Try the chipset driver first.
Please unzip the file before installation.
You maybe also need the driver for the usb controller.
Try to use a PS/2 mouse until the driver is installed.
Aug 28, 2011 | Biostar G31-M7 TE Motherboard
I purchased and Pointer Service installed DEsktop Dane-Elec PCIE 1x usb 3.0 card with 2 ports.I connected the mouse and keyboard into these 2 usb 3.0 ports.My motherboard asus p6x58d premium did...
This is an very new model of addon card for which there is no driver in the Express Gate - which is just a stripped down Slackware Linux operating system - so the system ignores it and everything plugged into it. Since adding a Linux driver (which doesn't even exist at this moment according to the manufacturer) to an embedded OS like that is extremely difficult you should just connect your keyboard and mouse in another onboard USB socket - if necessary use a $5 hub which you can buy at Walmart.
Feb 28, 2011 | Computers & Internet
Computer does not recognize the keyboard,, have windows xp 2002 sp3, and bot the USB keyboard/mouse from crayola. another keyboard that is USB works just fine, so not the port???
Sakar International makes this product.
According to them, your operating system isn't supported, although for the life of me I cannot see why.
Here are the supported operating systems:
System Requirements: --Windows 98SE, ME, 2000, XP or Vista --Mac OS X (10.1 or higher) --One available USB port
Here is the website for the mouse:
http://www.sakar.com/p-1602.aspx?return=y&txt=crayola&page=0
And here is the website for the keyboard:
http://www.sakar.com/p-1600.aspx?return=y&txt=crayola&page=0
I'm sorry I couldnt help more. This should be resolveable, but the company has no information on how to resolve it.
Oct 28, 2010 | Crayola Keyboard w Mouse and Mouse Pad...
My Right side SHIFT-KEY on a keyboard of HP-Compaq nx5000 Notebook is not working. Is there any solution?
maybe the under-button rubber is corupted try to clean it
also u can use the left one for a while.
Jun 05, 2009 | HP Compaq nx5000 Notebook
Inoperative keyboard
Keyboards are pretty standard, I've even gotten old AT style keyboards to work. If it can't be detected by your computer I would suspect either a bad port or a broken keyboard. The exception would be USB keyboards. They have to be enabled in the BIOS and even then there can be a short delay before they are initialized by the system.
Sep 16, 2008 | Microsoft Windows XP Professional
Keyboard not working
check how you have all plug utilized. if a USB keyboard in use or even wireless will not affect your internet connect. you may have a circuitry problem. Install another keyboard and see what occurs.
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
