Question about Sony Audio Players & Recorders
I need the speaker connectors for l----R - Sony Audio Players & Recorders
  • 1 more comment
  • christian johnson Feb 15, 2012
    I need the speaker connectors from left to right
    for sony SA-VA3A
    I need the connectors from left to right speaker for a sony speakers model # SA-VA3
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 231 Answers
You are in Personal Minidisc.
Posted on Apr 16, 2014
Hello how do I connect my speaker to my mac
Hello there, I am the Elite Expert that will be helping you today, my name is damnor01. Welcome to Fixya.
Go through my published guide entitled How to Install Speakers on your Computer/Laptop!!!
You will need to insert the connector from the speakers into the 3.5mm jack/connector on your laptop. You need to use audio out connector.
You may need to install driver that came with your skeakers, however if they didn't come with a drivers disk then drivers are not needed.
Happy Listening!
damnor01
Feb 09, 2011 | Bose Companion 2 Series II Multimedia...
I am looking for speakers to replace the ones that r in it.They r they original speakers that came with the car. Delco speakers-they have 1 adapter female plug on each side of the back speakers. Can't find...
any aftermarket speaker you buy will not have that style plug. you need to cut off the original connector on the wiring, and use the connector for the aftermarket speakers - there are a couple different style connectors, whoever you buy the speakers from can provide the proper connectors that you will crimp onto the wiring. good luck!
May 10, 2010 | 2000 Pontiac Grand Am GT
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
What does speaker cord for eT3205 look like? May not have been in
No question is stupid but it would help if you gave more information.
The basic cord for any speaker is 1/8" audio connector...
Nov 07, 2009 | Audio Players & Recorders
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Speaker cut out
The problem sounds like either the connectors from the radio to the speakers disconnecting.
To fix this I suggest you work out which speaker is getting is cutting in and out. Then you take the speaker out and check the connectors are attached to the speaker correctly. If the connectors are loose or don't have dirt or something stopping the from making a clean connection the speaker this can cause a problem.
If after checking the speaker connectors the problem persists you need to take the radio out can check the connectors on the radio have not come loose or anything.
If it still doesn't work after that I would then look to replace the radio, as if the speakers are working some of the time that would mean that the problem is probably with the radio not the speakers.
Hope that helps
Feb 05, 2009 | 1998 Ford Contour
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
