Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Genie garage door won't stay closed
  • 244 Answers
SOURCE: garage door slamming shut
springs are shot/wrong. door not balalnced.
Posted on Jan 15, 2009
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 31 Answers
SOURCE: Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
  • 3197 Answers
SOURCE: garage door will not stay closed. It raises
On the side of the motor unit you will find the 'down limit' control. Turn this in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
Posted on Nov 23, 2009
kirkx
  • 2019 Answers
SOURCE: Genie garage door will not close if safety photo eye sees sunlite
Most photo electric eyes have sensitivity settings. A small dial or screw that can be adjusted.
If there is none, then another trick would be to recess back further from the actual opening, and put is on the wall as far as possible.
Finally, you could add a tube to act as a sunshield. They probably have one that can be special ordered for it.
And it even that does not work, consider taping a sheet of polarized film over it, like a single sunglass lense.
Posted on Apr 20, 2010
Testimonial: "Your answer is very helpful and I thank you. Have a great day!!"
Garage door closes but doesn't stay closed
if nothing is obstructing the door then there are 2 possibilities:
a) your limit switch for closing is too low and the closer detects the motor stall as the floor is reached, then opens in case it's a kid under the door.
b) your tracks and garage door are mis-aligned, causing excessive force to trigger the reversal. Make sure the door closes easily by hand.
Jun 19, 2015 | Genie Powerlift 900 Garage Door Opener
Genie screw opener is louder when opening or closing ?
If its louder when opening check and see if your door is balanced properly. disengage opener raise door about half way it should stay there. another way is to raise the door all the way up with the opener then check and see if your cables are tight. if it balances right try adding a little genie grease to the screw while its running.
Aug 03, 2014 | Building Materials
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Gene garage door openers
are you sure that it doesn't just stay on for 30 seconds to one minute and then shut off? if it stays on all the time, the light switch has been manually turned on and you need to turn it onto 'automatic'
Mar 18, 2013 | Genie 1/2 HP DC CHAIN MOTOR
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
Jan 12, 2013 | Craftsman Sears Liftmaster Garage Door...
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Genie auto garage door. closes then imediately re...
GET A COPY OF THE ADJUSTMENT INSTUCTIONS FROM THE GENIE WEB SITE - IT IS A SMALL AND SIMPLE ADJUSTMENT - BUT, IF YOU MESS IT UP THE DOOR WOULD BE UNSAFE.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
135 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
