Question about Estate TEDS740JQ Electric Dryer
Estate dryer my dryer gets hot even on fluff mode and no heat
  • 67 Answers
There is a sensor in the exhaust near the motor, most likely that needs replaced
Posted on Oct 28, 2008
Electric dryer overheats
Fluff blocking filter or if condensor prob heat exchanger is fluffed up in front on bottom unclip and pull out
Jul 15, 2015 | Estate EED4400WQ Dryer
Estate gas dryer model egd4300sq0 wont get hot
check heater relay.Is it only in normal dry, or all modes including fluff?
Aug 21, 2014 | Dryers
Dryer is running WAY too hot.
Hi givn2fly
Your high temp thermostat is faulty, replace it.
Bud
Apr 04, 2013 | Frigidaire GLER341A Electric Dryer
Dryer not getting hot enough
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Estate TEDS840JQ Electric Dryer
I have a Whirlpool Estate Dryer model # TGDL640BW2 and the dryer will not get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Dryers
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
This Maytag Atlantis heats too hot; I cleaned off all the lint deposit from the drier itself and from the ducts, but it is still too hot, with heat coming out even in fluff. please help.
There are high/heat limit switches in the rear near the heating element. The switch needs to be replaced because its not shutting the heat off when it reaches correct temperature. Rear of dryer needs to be disassembled for this repair...............
Dec 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
When turning on the dryer it blows but it is not heating up. Everything else is working just find. It's just not getting hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Feb 08, 2010 | Estate TGDS740JQ Gas Dryer
Estate dryer will not get hot in any cycle, also will not turn off by itself
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model is always helpful when requesting information.
Unplug dryer before testing.
For your symptom the problem usually is the heater coil burned out. Inside rear cover in a can on the right side. A burned out coil will prevent heating and in the automatic cycle the timer will not advance if the heater is out. You can verify this by using the timed cycle. In timed dry the dryer should turn off even without heat.
Aug 22, 2009 | Estate Dryers
Estate TEDS740JQ Electric Dryer Logo
59 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
