Question about Yamaha Audio Players & Recorders
HOW TO HOOK UP SDAT 8
HOW ON EARTH DO I HOOK UP MY SDAT 8' POWERED SUBWOOFER TO MY HTR-5740 RECIEVER????
  • 341 Answers
You need a long enough subwoofer cable ( Male connectors on each end ) and connect it to the female RCA input on the sub and the rear of your receiver has an output labeled subwoofer out connect the other end of the cable there and you are good to go. Make sure both the receiver and the subwoofer are powered off when making the connections.
Posted on Feb 17, 2012
4 Suggested Answers
rteemon
  • 578 Answers
SOURCE: HTR-5740 Receiver Subwoofer Problem
as long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Posted on Jun 26, 2009
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
  • 11800 Answers
SOURCE: I have a yamaha htr 5740 - any suggestions how i
If by headset you are referring to an wired headphones and microphone set then just plug the headphones in the headphones jack - you will need an adaptor like
http://www.bit2u.lv/en/network/connect/BANDRIDGE_Headphone_Adapter_6_3mm_M_-_3_5mm_F_stereo_BAP664.html
and the microphone in one of the Audio inputs using this adaptor
http://www.audiogear.com/cgi-bin/shopper.cgi?key=ADPT2RCMQSF&preadd=action
If you want to be heard over another audio source then just buy 2 of these
http://www.audiogear.com/cgi-bin/shopper.cgi?key=Adpt-2RcfRcm&preadd=action and plug them in the audio inputs before the cables
Posted on Dec 10, 2010
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
I have a rca no rtd250 impedance 12 ohms subwoofer. how do i connect it to my yamaha htr 5940.do i need a special cabel where do i get it.
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Jan 14, 2010 | Yamaha HTR-5940 Receiver
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
I need a dishnetwok remote code for my HTR-5740 YAMAHA reciever
my phone say that initial programming needed can you sold this for me
Nov 01, 2009 | Yamaha HTR-5740 Receiver
How do i hook up my xbox360 to my yamaha 5740
You can use Optical SPDIF cable. Both yamaha and xbox supports it. You can find cheap optical cables on ebay ($1-5 max.)
Sep 02, 2009 | Yamaha HTR-6130 Receiver
Jun 26, 2009 | Yamaha HTR-5740 Receiver
I have linertec LA-8 olx Amp
IF ITS A POWERED SUB,,JUST USE RCA JACKS TO THE SUB TO THE RECIEVER VIA THE PLUG THAT SAYS SUB
May 14, 2009 | Yamaha HTR-5850 Receiver
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
73 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
