Question about Olympus Stylus 1030 SW Compact Camera Carrying Case
What does VGA mean - Olympus Stylus 1030 SW Compact Camera Carrying Case
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
VGA - video graphic array (640 x 480 pixels; 1.33:1 aspect ratio)
VGA - Via Gamers Arena
hope these will help
Posted on Feb 15, 2012
What does it mean when it says No VGA Cable
"No VGA Cable" typically means that the monitor does not include a VGA cable, which is the cable you need to connect it to your computer and get it to display properly. You will have to use/buy your own VGA cable to get the monitor to work properly.
Jul 09, 2014 | Dell IN1910N 19" Monitor
Stack when vibrating
actually , the problem
with cable for Display or VGA ship-set
problem , you have plug you laptop with external
Screen then check , if still " Vibrating "
check the driver for VGA , is it correct , if there is no problem with vga driver it means ,VGA ship-set problem
hope help you
BR
Mohamed Hejazi
HP Tech. Support
Nov 10, 2013 | HP Compaq nc6120 Notebook
I want the definition VGA card
A "VGA Card" would more commonly be called a Video card or Graphics card. This is what sends the video to your computer monitor. VGA is the name of the type of plug that the card uses to plug into the monitor. Video cards use VGA, DVI and HDMI for higher quality Video cards.
Thanks for using FixYa.
Aug 20, 2011 | Computers & Internet
A compaq sr1000 need to know what no VGA input means. Will no allow my computer to come on
Welcome to FixYa
No VGA input means that the computer is not detecting video input from the video card. Usually you get this message if the video card of your system is not functional, the VGA cable is unplugged or the VGA cable is defective. To try and remedy this problem try these.
Check if you can hear sound coming from the system. If the video card is functioning then you should here the startup audio from windows.
Check the VGA connection on the back of the system. The VGA cable looks like thismalups_6.jpg
Please note that the VGA cable has two screws, make sure that both are fastened correctly
If the VGA cable is plugged in and you cant hear audio coming from the system. Then this would likely be caused by a defective video card on your computer
Hope this helps
May 28, 2011 | Compaq Computers & Internet
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Powers on but no screen
There may be problem with your Monitor or VGA Card.
When you turn on computer after sometime the monitor light will be orange colour it mean there is no fault in monitor. VGA Card is not sending signal on the monitor. you should change your VGA Card slot if the problem is still exist. Replace the VGA card or have a local tech take a look at the VGA card.
Mar 16, 2010 | Computers & Internet
Im having no signal to the monitor and a vga error on the mother board try everything
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
Mar 12, 2010 | Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX...
Vga mode not compatable.. what does this mean.
YOUR COMPUTER IS UNABLE TO SUPPORT THAT VGA CARD MEANS THE VERSION IS OLD MUST BE DDR1
Jan 03, 2010 | E-Machines T2895 PC Desktop
What is the exact mane of the DVI to VGA adapter needed for dell optiplex GX 240?
Sorry, but what do you mean with mane (can't find a correct translation to dutch)
Do you mean advantage, or do you mean what you can do with it?
Normally a DVI to VGA adapter can be used to connect a display with a VGA connector to a DVI port. If you have 2 ports VGA and DVI, maybe you can connect 2 displays to your pc. It's great working with multiple displays, making your desktop twice the size. For example: you can open your mail program in one display and your web browser in the other.
Jul 22, 2009 | Dell Computers & Internet
Olympus Stylus 1030 SW Compact Camera Carrying Case Logo
62 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
