Question about Samsung CLP320 AllInOne Laser Printer
Clp-320 paper jam - Samsung CLP320 AllInOne Laser Printer
leroyal
  • 2120 Answers
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
Posted on Jan 05, 2009
snowman533
  • 33 Answers
SOURCE: SAMSUNG CLP 315 paper jam
the printer may be detecting dust or something on the sensor, and detecting it as a jam
try to get the sensors cleaned, tell us how you go
Posted on May 19, 2009
  • 13433 Answers
SOURCE: My Samsung CLP-510 printer shuts down frequently for paper jam. However, there is no paper jam. To fix, I turn off the power to the printer for 30 seconds and after turning the power back on the paper
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
jyvibar
  • 148 Answers
SOURCE: samsung clp 310 printer regularly jams
avoid using paper that is below 50 gsm
Posted on Mar 26, 2010
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
The paper keeps jamming in our Samsung laser printer 660 nd. We bought heavier paper for a laser printer but it still jams.
The ideal paper is around 80 GSM (gm2) if you are having problems with a BRAND NEW REAM of standard copy paper then your printer will need service.
paper that is thicker/heavier than this can actually cause more jams and problems and show worn out rollers earlier
These printers only tend to jam at the entry (pickup) near the base of the printer or in the fuser unit (hot area near the top)
if you are getting jams in multi page documents, have a look at which area the most crumpled piece of paper is in before you try and remove it.
the pick up rollers and separation pads are relatively cheap but the fuser units can be a bit pricey.
CLP 660ND CLP 660ND XAA Support SAMSUNG Canada
Sep 29, 2014 | Samsung CLP-660ND - - colour - laser -...
Output bin full
Power off your printer. Take out the papers and unplugged cables from it. Remove the cartridge and then check is anything jamming the paper inside.
After checking, reinsert the cartridge and plug the cables. Keep the paper and take a test print.
**You can also avail our technical support by visiting our website: http://www.vtechsquad.com
Apr 29, 2013 | Samsung Colour Laser CLP-320
Samsung clp 320 'door open' problem
If the printer was just powered up and immediately gave the door open error, look for a paper jam. When this happened to me, that was the problem, even though it was saying that the problem was an open door.
Aug 01, 2012 | Samsung CLP320 AllInOne Laser Printer
Samsung clp 310 printer regularly jams
Go to YouTube and watch this video: 5fJHykzkfww
I will try to add the video to this post. The sensor is available on eBay for around $8 to $12 and it takes only about 15 minutes to fix the printer.
Mar 26, 2010 | Samsung CLP 315 Laser Printer
My CLP-315W keeps jamming. I'm up against a
Paper jams. I have one of these printers. Do not over fill the paper tray. Make sure the paper path is clear (See owners manual). Make sure the paper is relatively dust free and give the paper a good shake or shuffle before adding to the tray.
You did not mention if the paper was just not picking up or if it was stuck in the printer?
Nov 16, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP 300 printer jams when using legal size paper. I've changed the paper size in the properties menu and it still jams every time. Help.
Make sure the paper setting in the printer driver software is set correctly. Sometimes that can cause this problem.
Aug 04, 2009 | Samsung CLP 300 Laser Printer
May 19, 2009 | Samsung CLP 315 Laser Printer
Paper jammed
how to unlarge a paper jam in the compaq A3000
May 27, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
Samsung CLP320 AllInOne Laser Printer Logo
404 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
