How to take apart speaker jbl tr125 - Audio Players & Recorders
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
How do i link 2x tr125 jbl speakers to 2 mr922 jbl speakers
The connections are pretty straight forward, but it will depend on what amplifier you're driving them with. Normally, I'd connect the two TR to one side of a stereo PA amp and the two MR to the other side. All four cabinets are rated at 8 ohms, so running tow parallel per side would give you a 4 ohm load on each channel which would be a common load for most stereo PA amps.
However all this would depend on your gear and what you need to accomplish. If what your question really meant is how do you connect all 4 to one channel, you can't as in most cases the total impedance would be too low and you'll fry your amp.
If you can be more specific about your system we could be more helpful.
Mar 17, 2015 | JBL Music
Jbl eon 1500 horn tests good 3.9 to 4.2 dc restance but will not work
You have probably blown a light bulb in the SonicGuard circuit. You will have to take the cabinet apart to check it.
Jan 05, 2015 | JBL Audio Players & Recorders
Is there a replacement amp for my jbl SCS180.6S subwoofer? I tested the speaker and it's fine. I also tested the output from the stereo and it is also fine. When the sub is turned on, there is a b
No you can't! I should contact JBL for the location of the part. Transformers are safety parts and should only be replaced by the same part or those approved for use by the maker of the unit.
Dec 20, 2012 | JBL Audio Players & Recorders
How do you remove the HF driver in the JBL EON 15 G2's??? Cheers Glen
If the cabinet is all taken apart, unplug the white and blue wires and unscrew the driver counter-clockwise to take it out
Feb 28, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My JBL Control 10 speakers cut out simultaneously. I have the speakers/receiver/lcd tv/xbox 360 all plugged into a giant surge protector and in the same outlet (no other option) and everything still works...
Hiya, I am guessing that the fried wires were the inputs to the speakers? If thats the case and they are damaged, then unfortunately both JBL could be blown, most likely preamp damage. Try taking them away from the system and using a completely different source like the output from a CD player/MD/ even video with a new cable. That will tell you if it is the speakers or the reciever you are using.
If they are damaged, you will need someone with electronics abilty to repair. If the input wires are damaged, there is a good chance there will no warranty, however discuss with JBL, then decide where they go for repair.
All the best
Aug 04, 2009 | JBL Control 1 Pro Main / Stereo Speaker
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
6x9s in a clio
forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
Dec 04, 2007 | JBL LC-S960 Car Speaker
78 people viewed this question
 Grubhead
Grubhead
