Question about Samsung SCX Office Equipment & Supplies
Problem with samsung series scx-6x22
After i finish my scan i move all the file into a folder. Suddenly all the file are an access denied. How i want to get the file back?plzzz help me
  • 167 Answers
SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
Posted on Oct 26, 2007
SOURCE: Can't scan documents
When I try to do a prescan I got the error message "Can't open SCX-4100 series"
Posted on Sep 29, 2008
SOURCE: Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position.
Posted on Jan 06, 2009
SOURCE: samsung scx-4200 does not give me the option to scan to pdf file
I used a program called SmarThru 4 with the same printer-scanner. Works. Give it a try :).
Posted on Sep 09, 2009
  • 33 Answers
SOURCE: how to download samsung SCX 4x 16 series scanner
goto www.samsung.com and use the search box at the top right and type in the exact model, the x to substitute for numbers/letters isnt helpful so type the exact model in there and it should have a page to download the drivers
Posted on Oct 08, 2009
How to save scan file as pdf with samsung laser mfp scx-4623
Dear if you are using smar through 4. scan the image using SCAT TO button-select FOLDER-SCAN-select the folder to save-select the file type to PDF to save-click on SAVE.
Thanks.
Aug 09, 2014 | Samsung Office Equipment & Supplies
Tip
Removing 'Access denied' error from folders and files using Unlocker Assistant
Copying files from one destination to another is a practice that goes on a lot among PC users. Sometimes huge sums of data are moved from one hard disk to another. Now there is this error that happens a lot where, when the mouse icon is placed on a folder, you see 'folder is empty' even though you know that the folder you copied is not empty. When you try to open it, you are told that access denied. Most of the files too may not be accessible and will also give access denied error. This is a frustration that can make one think that his/her files are lost. Well, there are ways out and even though it might take time, it's worth it. The following, is a solution to this problem using the software, Unlocker Assistant;
1. First, you would have to obtain the software on the internet. It's free and you can easily search and download it in a few seconds.
2. Install it by following the instructions and you are ready to go. Now, if you are using Super Copier, Unlocker Assistant may fail to start so if you do, then uninstall the Super Copier for the time you would use the Unlocker Assistant. You can install it back when done.
3. Now create a folder on another drive with enough space, different from the one with file and folder errors.
4. Now right-click a folder (one with access denied and empty folder error) and select 'Unlocker'. Among the list of actions, you select move and select the folder you created as destination. If the moving goes through, a success message will show and state that object was moved which means everything in that folder is fully unlocked and is accessible.
5. If the moving does not go through, it will ask you if you would like to move the object the next time you restart. If so, select no. Now refresh and check the folder again and you will see that this time, it is not empty and it is accessible. Now open the folder and repeat the same thing with all other sub-folders. Now this might take time depending on the number of folders you have so you might want to ignore folders that you do not need.
6. Now after you have unlocked the folders, you come to the files in the folders. Select all the files in the folder and right-click and select move. Create the same folder name at the destination for easy recognition. All the files will moved. If the file sizes are very big, you might want to take a little at a time but if they are all small, then you may select all.
7. Now every file that is moved by Unlocker is now accessible. Pictures, movies and all other file types can now be accessed. After everything, you may then move the files back to the disk that had the file and folder errors.
That is all. You are done. Hope this was helpful.
on Mar 04, 2010 | Computers & Internet
C:\ is not accessible access is denied
Try right clicking on the folder, then go to properties, then the security tab. You may have to change or edit some of the permissions in there.
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dv4-2165dx...
Scan
not click on preview just next finish
Apr 24, 2013 | Samsung SCX-4300 Monochrome Laser...
Always appear on the printer screen is "system initializing" I 've waited for about 30 minutes to initialize the printer but the sounds still like on the process of initialization.and its...
Hi
Don;t worry my friends we are here to solve your problem, Basically that problem is came when your cartridge is low or not fix the properly, Switch off your printer and plug out the power code,open the front side cartridge door, pull the cartridge and check the cartridge level, if the level in low then change the cartridge and put eh new cartridge.
Cheer
Jun 11, 2011 | Samsung SCX-6322DN All-In-One Laser...
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Hitachi SimpleDrive 320GB: Error moving file: Access denied!
The problem may be that your Security settings for the drive are not configured to give you Full Control.
In Explorer, right-click on the Hitachi drive and choose Properties.
Go to the Security tab.
Find the User you are trying to use and click on it.
Under Permissions, click Edit and enable Full Control for that user.
That should give you the ability to do what you need to.
If Windows won't allow you to change the setting, it's because you don't have Administrator priviledges. In that case, log out and log back in as an Administrator and go back and make the changes.
Nov 04, 2009 | Computers & Internet
Network scanning problem
scanning from any device is simple you need three things
   user name   bill    password    piguine    path            \\server\scans\shared folder
the scanner needs rights to write to  a folder on the network..  good luck
Apr 27, 2009 | Samsung Office Equipment & Supplies
Access is denied
Try to scan it with R-Studio or GetDataBack..
Oct 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
89 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
