Question about Toshiba Satellite A6653DV LED TruBrite 156Inch Laptop PSAW3U042001 PSAW3U042001 PC Notebook
Wifi on/off and keyboard light buttons on the system control panel not work satellitte A665
Hard drive failure. Installed OS from recovery Disc to new hard drive. All worked well to start with. Hoever when installing software the wifi and light button stop working. Also cannot excess wifi with the F8 button message use switch to turn on wifi. I've used recovery 4 times with backup between install software to determine what might be causing the problem, however the problem is ramdom. I thinking it could be windows 7 update in the background causing the problem
Pyrhyc
  • 2028 Answers
SOURCE: Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Posted on Jul 02, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Recovery
Windows XP does have RAID drivers, but it really doesn't have anything to do with this problem. Try a bios flash with either updated bios version, if any, or the original bios. Your problem is much deeper that a hard drive or operating system. Your problem is in the motherboard, if the bios flash doesn't do it, then the motherboard may need to be replaced. Take it to a tech and have them run down the exact problem.
Posted on Jul 07, 2008
mnelsonix
  • 58 Answers
SOURCE: how to recovery the system from recovery partition
Did you know you only get ONE shot at creating a recovery disc? And most of the time it is garbage, just like Vista.
He tried to put XP on it and failed? weird.
A couple things you can do...
1. Get your hands on a Vista disk. If you know anyone that works in IT, you can borrow a Vista disk. Do a complete fresh install. Use your "Product Key" and you will have your own Licensed, perfectly legal version of Vista.
2. Get yourself a copy of XP. Delete all partitions, then create a new one. Don't try to save that Vista recovery partition...it's toast. I recommend XP, but I'm a dinosaur.
Posted on Apr 07, 2009
  • 1584 Answers
SOURCE: toshiba qosmio f45 av412 system control panel
I assume you mean the volume bar.....if so its the wrong driver for Win 7
Posted on Mar 26, 2010
SOURCE: Recovery Disc will not load OS on HD
laptop panasonic toughbook bios password pro
Posted on Apr 07, 2010
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
My toshiba laptop won't let me do anything it just says no bootable device insert a boot disk
Hi what OS ? (win 7, xp)
have you tried to check the Bios to see if it picks up the hard drive?
(on boot up, push the delete or F10 or ESC buttons) One of the buttons will get you into the bios then check the boot options or the standard information. You can also set the default values and save.
If you have Win 7 then get Win7 cd and let boot up from the CD. You can choose to repair and this normally works well.
Dec 22, 2012 | Computers & Internet
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
I am installing a vantect 6-port sata II 150 pci host card w/raid model ugt-st310r. i am installing 3 new western digital 500gb hd. i configure the raid and go to install the OS and i get a blue screen...
make sure you ram modules are securely seated if you are getting the blue screen of death you might not have enough ram installed (being recognised by your computer) to cope with the ammount of programs installed on your hard drive also
test the leads from motherboard to hard drive make sure they are securely seated
want to know what the problem is
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if I have misunderstood the problem post a reply
hope this helps you
Sep 11, 2011 | Vantec UGTST310R PCI Host Card 6 Port 4...
My internal hard drive crashed, can i clear out this hard drive and reload the system and start up disks or should i just get a new hard drive. Also is there any way to retrieve files from the crashed...
Hi I am Steve, lets get you some help
As you are talking about a hard drive I assume you have turned off RAID.
It does depend why the hard drive has failed. If it is an actual failure of the drive then it needs replacing and the data is lost except from data recovery firms.
However, it may be that the hard disk controller has stopped working. This will prevent you getting to your hard disc.
Your motherboard should have 2 hard disc controllers. Try plugging the hard disc into the second controller, this will be on the motherboard next the the one it is already plugged into. This may solve the issue. If not then it is a hard disc failure and you will need to replace it and use a professional service to recover the data.
Jan 14, 2011 | Gateway (M520HD80G) Hard Drive
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
Toshiba Satellite A6653DV LED TruBrite 156Inch Laptop  PSAW3U042001 PSAW3U042001 PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
