Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My macbook battery is not charging
Battery not charging
  • 3 Answers
This issue could be due to 2 different issues.
1. Your battery is dead.
2. Your power cable is dead.
If your power cable still lights up green when you plug it in then the issue is most likely due to your battery. Since you have a old Macbook it is probably not under warranty therefore you will have to pay for the repair. You could either have Apple replace the battery for you or if you could buy a battery online and do it yourself.
Posted on Feb 25, 2012
Battery charge doesn't hold in MacBook 2009
You can install a program from the app store called "Battery Health". It will tell you if there is anything wrong with your battery. You may need to replace the battery, you can buy the $100 battery that Apple sells, but I have bought batteries for both of my macbooks from this place: http://www.ebay.com/usr/masione_outlet?_trksid=p2047675.l2559
Dec 29, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook battery not charging
If it is under a year old, then you may have a case for a free replacement by Apple. If it is older, then you'll have to buy a new battery and recycle the old one. All laptop batteries have a maximum lifespan and will have to be replaced at some point in the future.
Feb 15, 2012 | Apple MacBook Mac Notebook
My MacBook wont charge
So does the organge light still not come on now? If it doesn't try a different charger first. If that fails, your DC-Jack module or logic board may need to be replaced. There are detailed instructions on how to do the restore online. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jun 19, 2010 | Apple iBook Mac Notebook
Battery will not charge. Best buy and IT dept
The issue could also be with the MagSafe adapter because if that power cord is not working, your Macbook's battery will fail to charge as well.
If you are able to get your MagSafe Power adapter tested and it works, then yes, the Best Buy Geek Squad you communicated would, be correct in assessing that the issue is more than likely the main logic board due to the connectivity from the MagSafe port to the main logic board.
So my suggestion, before allowing any tech support service to conclude that the main logic board is the reason your battery will not charge, have that MagSafe power adapter checked and actually, now that I think about it, have your battery checked as well, because it may be defective.
It is not uncommon for a Macbook battery to become defective early in its use.
To bring this answer full circle for you, have these components checked first, before accepting that the main logic board is the issue.
If you need to visit an Apple retail store Genius bar, I would recommend you do, because they have all the tools needed to check your Macbook and provide you the full diagnostics to isolate the reason for the battery not charging.
To find the nearest Apple retail store near you, just click this link:
http://www.apple.com/retail
Working to provide options to save you money here!
Thanks for using FixYa Support.
Best Regards,
-Terry
Mar 16, 2010 | Apple MacBook Mac Notebook
Macbook battery level shows fully charged at 83 percent instead of 100 percent. Is this a power inverter problem? It's a first generation Macbook
Most likely this is because you are loosing cells in your battery; the same ageing process that happens to us all. I'm guessing that in System Profiler under Battery it says 100-200 cycles or more. You cannot do anything to stop or reverse this. To prolong the life of your battery, once you unplug your power cable, keep it unplugged until (a bit after) it asks for you to put it in, and then leave it there until fully charged.
Oct 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook Battery Problems
Hi Molle
To answer your last question first. It is best if possible to use the mains power when you are using your macBook and only use the battery when you cannot connect to mains.
MacBook batteries have a life span based on the number of charge cycles the battery has been through. The battery has a max of 300 cycles before it starts to loss its charge capability. SO you need to determine the health of the battery is it chargeing etc. You can do this via the apple menu and 'about this mac'
http://support.apple.com/kb/HT1519
Check the health of the battery as the battery could be faulty if it has only cycled a few times or it may have gone over the 300 and is now lossing its charge in which case you'll need to get a new one.
Hope that helps
Paul
Sep 04, 2008 | Apple MacBook Mac Notebook
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
140 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
