Question about Dell Inspiron 531s Desktop Computer
My inspiron 531 says no boot device available
I'll try to reboot my computer and at first it says press F1 to reboot so i do then this message appears: No boot device available SATA 0: installed SATA 1: installed SATA 2; none SATA : none
  • Dell Master
  • 998 Answers
Computer is not configured to boot from your hard disk drive (SATA 0),
you need to go into the BIOS (set-up) menu and make that drive the fisrt boot device.
Posted on May 06, 2014
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: inspiron 531 wont boot up.
If yo are sure that you have a working operating system on your hard disk , and this error started after you (probably) defaulted the Bios settings or something else did ....Than I think the lack of sata raid driver makes the reading of your hard disk impossible ..To fix this ..either try to reinstall the operation system and during it ..choose to add a 3rd party driver (look for raid driver on your motherboard cd ..or on the manufacturer's support site ) ..or ..just get into Bios again ..look for the HDD in the advanced options ..and select the hdd 0 ..and eliminate the achi feature ..and replace it with sata as ide ..or compatible ..and save settings with F10 and restart ..It will make the hdd visible ..and support installation if it has non ...or just boot up ..but will work as IDE and not raid ..
Posted on Aug 24, 2011
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
When I boot My Dell Inspiron 531, it goes to a screen that says it can't find the Floppy Disk Drive, and says, at the bottom, to press F1 to reboot, or F2 to change the settings.
Simply press F2 and the screen probably a blue color with lots of settings you are talking about is BIOS setup. In this setup find a tab named "Boot setting" or something similar and go inside this menu. You will find devices and look for floppy drive and set is "Disabled". Save and exit. Error will disappear.
Jan 16, 2013 | Dell Inspiron Computers & Internet
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Recently acquired a Dell Inspiron 530s, having 2 problems. First, it won't boot right into Windows (Vista), asks to hit an F key (after hitting F1, it goes right into Windows). I went into Setup and a
It's a 'failsafe' - You will need to go back into the BIOS - double check the boot settings - and verify the HDD is set to Auto - make sure the RAM installed is the RAM shown on the boot screen.
Ok, once that is done reboot 2x - hit no keys - if it request F1 to continue, CTRL/ALT/DEL reboot. - go into BIOS, go to boot options find the part that states "stop on error" and disable that... reboot.
If that doesn't help Contact me here. I've other solutions to try as it is a DELL and I've dealt with them for years.
Dec 09, 2011 | Dell Inspiron 530s Desktop Computer...
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
I installed a hitachi 500gb hd in my computer using a serial ata cable , but when i turned the computer on I get an error message "Reboot and Select proper Boot device or Inster Boot Media in...
your computer is trying to boot from the new istalled drive instead of the drive containing the operating system,
you could try swapping the SATA cables on the mother board, or enter the BIOS by rebooting and at start up, holding the correct key (acording to the manual) then look for BOOT DEVICE some where in the BIOS menu, change the boot device to the correct hard drive (the one containing the operating system)
Have fun!
Dec 31, 2010 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Dell Inspiron 531s Desktop Computer   Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
