Question about Dell (E210882) Motherboard
Can i solder a video card slot onto my E210882 motherboard if it has the spot for it
It has the spot for there to be one and i have the slot to go there but will it work afterwards is what i want to know
  • joecoolvette
    joecoolvette Feb 19, 2012
    No, johndoe. There are capacitors used as Filters, that are also left out.
  • 807 Answers
You could solder it in but it may need other components that were left of the board on that model. It needs to be able to communicate with other parts of the board to work.
Posted on Feb 15, 2012
Testimonial: "ok thanks"
5 Suggested Answers
  • 80 Answers
SOURCE: E210882 is the number on the motherboard on my
You can disable the onboard by visiting your bios.
On boot it will tell you to press del f8 f2 etc to enter the setup from there you can navigate around to disable the onboard and choose the lane your older pci card is in.
Posted on Oct 12, 2009
Coldcut
  • 1554 Answers
SOURCE: Memory for Del E210882 motherboard
download and run the dell diagnostics memory test on one memory card at a time .
or run with one then switch . does only one fail .
and what is the board GX or dimension.
GX is really particular about memory.
Posted on Mar 31, 2008
degcomputers
  • 13 Answers
SOURCE: Upgrading graphics card onto gx280 motherboard
You need to find a "PCI Express" video card. Your Motherboard does not have an AGP slot. There are lots of them to choose from. Better to pay more now and get more memory on the video card than to regret the purchase and buy another one. IMHO
Posted on Jan 18, 2009
SOURCE: how do i remove the
Hi macssword,
I see that you want to remove the VGA adapter on you dell motherboar.
I do not think removing it from the motherboard is a good idea, maybe disabling it will be best rather than removing it, it is bult in on the board and removing it may damage the whole motherboard.
If I may ask are you trying to use an Expansion Video Card on you motherboard?
If so you just need to connect the Video card on the Board then as soon as you turn the machine ON tap on F1 to get into the BIOS of the system.
Once in the BIOS look for the PCI devices option then you should see the option regarding the Video Cards on the motherboard you can enable and disable which video cardyou want to use from there on.
I hope this helps.
Have a nice day
mvincentc
Posted on Jun 09, 2011
I have an AA A83421-107 motherboard, E210882. I want to upgrade the video card and was wondering what the details are for my mother board?
Your model 4500 has an AGP slot for video cards. The Accelerated Graphics Port (often shortened to AGP) is a high-speed point-to-point channel for attaching a video card to a computer's motherboard, primarily to assist in the acceleration of 3D computer graphics. Since 2004, AGP has been progressively phased out in favor of PCI Express.
Here is a link to the technical specs of your motherboard:
http://support.dell.com/support/edocs/systems/dim4500/specs.htm#1101572
Jun 24, 2011 | Dell Dimension 4500 PC Desktop
I was just wondering where to put my Graphics card in my computer :S In one of these white slots? The only number i could find on it was E210882
I depends upon the type of graphics card you have purchased. The white slots are PCI expansion slots
and if the there is a longer slot in the middle of the motherboard next to the PCI slots, then it will be a AGP expansion slot.
APG graphics card are better graphics cards and these slots are designed for these graphics cards.
Dec 20, 2010 | Dell (E210882) Motherboard
E210882 motherboard. My graphics card went bad and i was wondering if this motherboard supports agp1.0 or agp2.0 graphics cards. I read that the voltage is different for the 1.0 vs 2.0 and wanted to...
For this motherboard you can use any AGP veido card they should work fine with it since this one is using AGP 3.0 but that is not a problem the version number only tells us the max speed of the video card will be running using this motherboard.
For the compete details about this motherboard go to this link.
http://www.gearxs.com/gearxs/product_info.php?products_id=8076
Aug 15, 2010 | Dell (E210882) Motherboard
Video/monitor plug in back of pc brpken off of motherboard. Can I purchase a video card so my monitor will work or do i have to have the connector soldered back on to the Motherboard ?
Forget about soldering anything back on.
If you can a descrete graphics card slot free, yes just buy a cheap card.
Check your manual for the type of slot available, if any
It will be AGP if its quite old, or PCI Express.
If no slot its a new Mobo
Jul 02, 2010 | HP Compaq Presario SR2020NX PC Desktop
945GCT - HM motherboard, SPDIF out?
Hi, Before doing anything please refer the motherboard manual, and as per my knowledge you need not solder any pin on the board, if you do so may be something else might not work. I better suggest you to check the Manual before doing anything.
Regards
Feb 22, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
E210882 motherboard powers on but then i get beep code... short 111-11
Remove the RAM from the slot and clean it. after that stick it back on the ram slot and try . If the same sound again then pull back the ram & put in a other ram slot. If you face same problem again then your RAM is damaged. For confirmation just use your ram in different motherboard. If its working there, then your motherboard ram slot not connecting well with motherboard. You need to repair your motherboard.
Thanks & waiting for your feedback.
Feb 12, 2010 | Dell (E210882) Motherboard
Mar 30, 2008 | Dell (E210882) Motherboard
Dell e210882 motherboard manual
It will go in any PCI slot.When you boot the machine it should come up with found new hardware wizard.Follow instructions.If new hardware wizard does not pop up go to control panel,then dbl click on add new hardware and follow prompts,it will ask if you have the disc if you dont it has options for what hardware you are trying to install.If you do have the disc you can  put the disc in the CD dirve and it should automatically start,if not click on my computer dbl click your drive where you put the disc and when the program opens click on install,
Mar 25, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
1,265 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
