Question about Home
Toilet fills up very very slow
Takes 10-15 min to fill up the water tank
  • contadino Mar 07, 2009
    We have a toto dual flush and when we flush, the water stops filling, then starts slowly and then finishes normally. Help!
    Problem Solver:
  • 11 Answers
REMOVE FILL LINE FROM VALVE. HOLD IN BUCKET AND TURN WATER ON, IF GOOD PRESSURE REPLACE COMMODE FILL VALVE. IF BAD PRESSURE CHECK FOR BLOCK ON LINE IT MAY HAVE SEDIMENT ON THE FILTERS.
Posted on Oct 27, 2008
Flow of water into american standard toilet tank is very slow and does not fill up to water mark
Adjust the level of the float, water level should be about 1/2" below top of overflow pipe. Slow filling can be due to a build up of calcium in fill vale, a partially blocked water valve, the washer many times gets deteriorated by the chlorine in the water, breaks up and clogs the fill line. Also many manufacturers (fluid-master in particular) place water restrictors inside the bottom of the fill tubes, which cause the water to fill much slower.
May 11, 2014 | American Standard Home
Tank take 0ver 10 mins to fill
What about sand? There may be a screen in the filler that is dirty and needs to be cleaned.
May 11, 2013 | Jacuzzi Bath Perfecta EZ33 959 White round...
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
I can see water trickeling on the bottom of the overflow tube. Already replaced gasket and removed the fill tube. Very slow, about every 20 min. the fill valve kicks on for about 5 sec.
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
Aug 23, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
New KOHLer toilet, worked great 2months... now fills slow 4-5 minutes for tank to fill, all the while it never quits filling, also, water runs from the little white tube into the overflow tube all the...
the fill assemly ( called the ball and ****) is bad cost about 8.00 at the hardware store, take about 10 min too replace,
instructions are in or on the box!!!
Mar 20, 2010 | Plumbing
Our American Standard toilet flushes ok but fills back up real slow. Very little water comes out of the hose that goes in to that tube. Can you help Thanks Howard
Okay Howard. It seems that the fill or float valve inside the toilet tank needs to be replaced. If you have a pair of channel locks / large pliers and some patience, you can do this yourself and save $ on a service call. This Solution is providing that you have good water pressure everywhere else in the house. First turn off the water on the supply line going to the tank. Flush the toilet (with the water off) to empty the tank. Take a towel / sponge / or wet vac to remove any remaining water. Remove the nut on the underside of the tank that holds the float / water supply to the tank. Now that you have the water float removed you can go to your local hardware store / Home Depot / or Plumbing Supplies Store and get a new fill valve. There are different kinds but they all do the same thing, fill your tank. I use a Fluid Master, But you may have to use one like you have. The Store will assist you. They are only about $10 - $15 Bucks or so.......Install the new float according to directions.....It is pretty simple. Insert your new float stem into the hole with the proper rubber washers and tighten carefully for a good seal. Insert the new black hose into the overflow tube and you are in business. You will have to adjust the water level to about a 1/4 Inch below the overflow tube for a good flush!!! I hope this helps you with the slow tank fill.............Joe
Jan 13, 2009 | American Standard Colony 2388.012.222...
Home Logo
2,287 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
