Acer Keyboard
Problem for Acer (90.46907.001) Keyboard
My Acer Keyboard wont respond when i press the key's
By UNKN0WN on Oct 25, 2008
Im having a problem. when i press G and Y and stuff on my other computer the censer of the keyboard is flashing but it doesn't type anything on the notepad, word and anything esle where you can type
does anyone have a solution to this?
Same Problem
Mar 31, 2009
-   I have the same thing! with more random keys-   Guest
Jan 10, 2009
-   My Acer keyboard is not responding on several keys and I have cleaned the leys with compressed air and the keyboard brush and still it doesn't work-   lavita2
Solution #1
posted on Aug 31, 2009
Not Rated)
stefdiy
Rank: Apprentice
Rating: 0%, 0 votes
A few days ago my acer laptop aspire 1640z , began to behave slower than usual when typing on the keyboard. At first I thought it was a virus, I did all the necessary scans and found none.
I then thought it might be the Keyboard driver, but it wasn’t.
I went into safe mode by keeping F8 down when you start the computer and select the directory service restore mode, which resets certain applications back to its original state. I found that my internet AOL connection and explore and fire fox would not connect to the net. Make sure you have a disk for AOL or setup file for fire fox saved, to reinstall the software. This seemed to work a bit but by accident, I remove the battery from my laptop and kept the power cord connect and Wow! it works even faster than before.
I have also notice that my battery does not hold a charge anymore. My theory is that because the battery is in critical status when connected to laptop…. (Even though the power cord is connected), the computer thinks that its going to run out of power and wants to go into hibernation mode which slows everything down including typing on the keyboard.
So before you try the safe mode option, remove the battery and use only the power cord cable and see if this solves the problem. Mine is running fine again ,but when I put battery back it slows down again. I read on the net its affecting only Acer Laptops, probably because the way the power settings software is set up for the Acers.
Stephen P
Was this helpful?
Yes
No
Popular Solutions for Acer Keyboard
Questions and Unsolved Problems for Acer Keyboard
Do you recommend Acer (90.46907.001) Keyboard?
Answer
Answer
No problem but read there could be a problem using the Logitech diNovo Wireless Keyboard - Mac... (More)
Answer
Just received a new Dell vostro 220 computer and a Dell keyboard. There is a key that I'm not... (More)
Answer
I need to order onnline keybord for acer aspire 6930 6154.can you send me some web site?
Answer
When i try to copy files using the shortcut keys ctrl and c all I get is an asterisk when I then... (More)
Answer
When I hit the "shift" and 2 to get the @ i get " instead and the same goes for... (More)
Describe your Keyboards and Mice problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Keyboard and Mice Experts
Top Computer & Laptop Repairmen
in , MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
