Question about Toshiba Satellite A135-S4527 Notebook
Powerpoint 2007 get sound from one monitor to another
Hi all, I was wondering how you would transfer sound from a labtop to an external monitor during powerpoint presentations. I use a standard 15 way to 15 way d-type connector to connector from lallbtop to plasma screen. the images display correctly but I cannot get sound, any ideas
  • houseandsolu Oct 26, 2008
    thanks guys, that was very helpful
  • 43 Answers
Some monitors have speakers built-in, some don't. The sound never travels through the 15pin d-type VGA connector. If the monitor has sound, there will be a small 1/8 inch stereo jack in the back or bottom of the monitor. Most all laptops have a headphone output jack (again 1/8 inch stereo) which is perfect for patching to external amplified speakers or to a monitor with speakers built-in. This patch cable can be purchased at Radio Shack, Best Buy, etc etc.
Posted on Oct 25, 2008
  • carey w mason
    carey w mason Oct 25, 2008
    If you are connecting to a Plasma TV and not a LCD monitor, you may
    have choice of connecting to audio input on the TV or into your
    amplifier. In both these cases the cable needed would be 1/8in stereo
    plug (at laptop side) to dual RCA plugs (at TV/amplifier side).
I cannot connect to video projection my labtop is vio VGN-SZ28gp Video projection cable do not recognize my labtop!
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Apr 18, 2011 | Sony Vaio VGN-SZ28GP/C Laptop Charger...
My ppt file got damaged i cant open it.while i try to open tat its asking for repair option.after selecting repair option it not opening,anybody tell me the ways to open tat file
If the file is damaged you could be out of luck.
There are how ever some things you could try.
http://office.microsoft.com/en-us/powerpoint-help/recover-a-corrupt-powerpoint-file-HA001116878.aspx
There are also 3. party software made.
Try searching powerpoint recovery tool etc.
How successfull any of these sollutions are depends on the actuall error,
Dec 23, 2010 | Microsoft Office Professional 2007 Full...
So I'm turning on my inspiron 5100 and all i get is a white screen. It sounds like it's on but the screen remains blank white?
Hi Donny,
A white screen usually means the LCD panel has failed/worn out. Here's an easy way to make sure. Get your laptop to an external monitor, whether at your home or a friend's place, and with the laptop off and the external monitor off, connect the monitor video (vga) cable to your laptop. Turn them both on and then on your Dell laptop hold down the fn key down in the bottom left hand corner of the keyboard and press the F8 key up at the top. That transfers the video signal to the external monitor.
If the external monitor shows your laptops normal desktop and icons, then you know for sure the LCD screen on your laptop is worn out. If you get the same white screen on the external monitor, it means the video card/controller on the motherboard of your laptop has worn out and you can move ahead with deciding on repairs or other options.
Good Luck.
PS....if the F8 key doesn't transfer the video signal. look at all the F keys for one that says CRT or one that has a little picture of a monitor to transfer the signal.
Sep 01, 2010 | Dell Inspiron 5100 Notebook
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
I am running Windows XP on my laptop. I plan to give a presentation using Powerpoint, and I'd like to plug a projector into the laptop. I cannot figure out how to play Powerpoint's presentation on the...
Couple ways. If you hook up the projector before turning on the laptop it should work. The preferred way, however, is to 'toggle' to the external moniter on your keyboard. Look for a icon on the Function keys (usually F4 or F5) on the top of your keyboard that looks like an external display. It may have a color, like green. It the lower left there maybe a key of the same color. You need to hold the lower left key while pressing the F key at the top. It will likely toggle between the external monitor only, both monitors, and internal only. Good luck.
Jan 07, 2010 | Computers & Internet
Mouse pad cursor doesn't work
try using the FN key with the monitor/VGA output selection changer(usually F5). You will see a little icon that looks like two monitors. Mouse control may have been changed to the external monitor connection. See if pressing FN(function) and holding that key and then pressing the monitor key will bring back your mouse indicator. You may need to do it with the projector connected and on.
Sep 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Pptx file converter for office 2007 to office 2003
I am looking for office 2003 2007 converter for using with a word doc
Jul 25, 2008 | Microsoft Office Professional 2007 Full...
Using IBM T34 with docking station and external monitor
hi all u need is to adjust the power management settings in the control panel, let me know
Jan 02, 2008 | IBM ThinkPad T43 Notebook
PowerPoint with an external monitor
A video driver update has been released to resolve that issue. Contact Technical Support at 800-632-4525 to request the file MP780-Display.exe from the password download section.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Toshiba Satellite A135-S4527 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
