Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Removing primer bulb on toro weed trimmer 51932A
5 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: I have a poulan pro 331 trimmer. The primer bulb
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jul 02, 2009
  • 1169 Answers
SOURCE: My Poulan Pro weed trimmer SM132 does not run.
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Posted on Aug 24, 2009
  • 20 Answers
SOURCE: I REPLACED THE PRIMER BULB AND NOW THE TRIMMER
Try swapping the hoses at the primer bulb. You may have put the return hose on the purge side of the primer bulb.
Posted on Oct 16, 2010
rycgl
  • 1545 Answers
SOURCE: why does my primer bulb when pushed stay push in
You may have a clogged in tank fuel filter, lines in the tank broken off of the fuel filter and line fragments clogging the fuel lines. . Fuel lines get flaky when they deteriorate. Your primer bulb may be leaking also. The check valves in the carburetor control the flow of fuel in and out of the primer bulb. The carb may need cleaning. In other words, a complete fuel system assembly inspection will be needed. If the bulb is on the carb, the check valves in the base assembly below it may be sticking. Remove bulb and spray in there with WD-40 to free frozen or sticking check valves. The valves are very small and malfunction occasionally
Start your inspection at the fuel tank and work your way to the carb. Pull the cover off the carb on the end opposite the end with the vent hole in the cover. You will be pulling off the fuel pump cover. Inside the carb body you will find a very small round fine mesh screen. Clean it well with carb cleaner and when you reassemble, spray some WD-40 in that area too.
Posted on Nov 11, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
I have a craftsman quantum. Weed trimmer and won't prime gas to the carb, what do I look for?
fuel in the tank, cracked hoses to the primer , primer bulb cracked, primer valves affected by rubbish, grass or failed
May 22, 2016 | Craftsman Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Need to replace the primer bulb
There is no primer bulb on an electric string trimmer. Is this a trick question?????
Aug 28, 2011 | Toro& Electric String Trimmer
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
1,202 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
