Sony Screen Colors
My Sony PC monitor (15 inch flat screen) has an overpowering orange tint to all colors. Like looking at it through orange colored sunglasses. Tried to reset and have rebooted but no resolution. Any ideas?
  • 348 Answers
It may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Posted on Oct 27, 2008
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
The screen has a dark green tint and cannot be adjusted. More specifically, the green section of the RGB setting on the monitor can't be changed (the G setting is permanently gray and I cannot move to that...
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
Apr 02, 2011 | Sony SDM-HS73P 17" LCD Monitor
The colour on the screen and the colour of the prints is not the same. Do you know what the problem is and how to fix it?
mlatham990,
First I would make sure that you have not run out of one color of ink, which will make the colors look funny. This is the most likely problem and can be solved by replacing the cartridge. If you print a test page it should be obvious if a color is missing.
If you are absolutely sure that there is not a color missing then the following information may be helpful.
There is no adjustment for the relationship of the colors at the printer. Depending on the monitor you have you may be able to go into the menu and adjust the tint, which is the relationship of the three colors, but generally monitors use an RGB signal and you cannot adjust the relationship.
If you can adjust the color tint I would print out a test page, or something with the color which is wrong, and then compare the colors on the page to the color on the screen while adjusting the tint to make the two match.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 26, 2010 | Epson Stylus Photo R340 InkJet Printer
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Apr 17, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Problems with screen display colors
If you seeing an absence of greens it usually means your connector at the back of the flat panel are not tightened firmly. Use a screwdriver to get them snug. The same goes for the connector at the back of the PC.
May 09, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Computers & Internet Logo
461 people viewed this question
David Payne
David Payne
