Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Sony 42" Plasma
My plasma tv has 1 2" black line that runs down the center of the screen. Does anyone know why this is happening and how i may be able to get if fixed. Thank you.
  • patziegler Sep 21, 2008
    I have a Sony 40" LCD with a line down the middle of the screen. It started at the top with a length of about 5". Gradually it has grown to the bottom of the screen. How can I repair this?
  • t_bandith Jan 18, 2009
    if anyone has solution. Please post it. I could use your help. thanks in advance
    Champion:
  • 217 Answers
This could be caused by a buffer board on the lower part inside the set
Posted on Feb 18, 2007
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Black line on Plasma Tv
Hi my name is Eric,
I hope I can help you with your issue ,
Bad news is you need a new panel. that is the screen itself.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 27, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black line in the middle of screen
It is possible the connector to from the address board to the screen may be need to be cleaned & re-seated, but almost 99% of the time this fault is a problem within the plasma screen & the only solution is for a replacement screen.
Aug 14, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
Apr 12, 2008 | Hyundai ImageQuest HP4240 42 in. Plasma...
Sony 42" Plasma TV
this tv fail from loose ribon cable plug, but I dont recomend you to work with it, becouse you cand spoil and easy job for the tech, and will cost you more, so get a tech, will be better...good luck
Aug 09, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
209 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
