Question about Dometic Refrigerators
I need schematics for a dometic royale rm 3600 refrigerator
I need the electric chematics
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
SOURCE: How many amps does a unit like this use?
According to the label (inside the hinge of the main door), it's 2.7 amps when running on 110 volts. It shows blank for running on 12 volts. However, with the anti-humidity switch on, it can use enough current to drain your battery. I was concerned about the battery draw when running the fridge on 12 volts, because the dealer told me it defrosts itself every 72 hours. Something has to control this, and probably uses some power.
Posted on Jul 25, 2009
  • 2187 Answers
SOURCE: DOMETIC RM 2214 Refrigerator in Travel Trailer
Check first if the distance of the fridge to the wall is enough or has similar air circulation as with its previous location. Inspect the coil at the back of the freezer for dirt or ice build up. See if cleaning the unit including the back of the freezer will help.
Posted on Aug 22, 2009
kdgrayson
  • 195 Answers
SOURCE: MY DOMETIC ROYALE 2002 RM 3862 2-WAY REFRIGERATOR IS NOT
You have a ammonia system, you need to remove the unit and turn upside down for 1 day min! then , clean entire burner area, it may look ok but if not done will not work well.
I am an old ac heater man and know the ammonia gets trapped up top and needs to return to the bottom , I know it works.
Posted on Aug 25, 2009
My dometic fridge will run on electric but not gas
The gas lines are pretty sensitive to corrosion. A lot of times you just need to gently clean off the tip of the line that feeds the gas next to the igniter. Check your igniter as well.
Aug 14, 2014 | Dometic Refrigerators
I have a dometic rm 2401 and it won't work on
yes, pretty common issue with that model
May 10, 2012 | Refrigerators
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
Aug 25, 2009 | Refrigerators
The red light is blinking on the front of fridge this means what?
SOUNDS LIKE THE WATER FILTER NEEDS TO BE REPLACED WHICH SHOULD BE ON THE INSIDE OF THE REFRIGERATOR NEAR THE BACK AND AFTER THAT YOU MUST HOLD THE FILTER BUTTON FOR THREE TO FIVE SECONDS TO RESET THE FILTER REMINDER.
May 04, 2009 | Dometic RM2852 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
69 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
