Question about Maytag Dryers
Remove front panel maytag med5600tq - Maytag Dryers
3 Suggested Answers
  • 2468 Answers
SOURCE: open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Posted on Apr 19, 2010
Jahn27
  • 1554 Answers
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Posted on Apr 21, 2010
How do I remove the front panel of maytag LDE7304ACM?
Type Maytag LDE7304ACM remove front door into YouTube and see if the video comes up, thanks!
Feb 20, 2015 | Maytag Dryers
What year was MED5600TQ0 Maytag electric dryer produced?
Check the date code on your unit against the chart below to get the mfg date. Maytag Date Codes The breakdown for Maytag Serial Numbers is:
1st Alpha Character (9th position) = Year Manufactured
2nd Alpha Character (10th position) = Month Manufactured
or go here: Maytag Date Codes
Nov 05, 2014 | Maytag MED5600TQ Electric Dryer
How do i get the drum off?
What you do first is unplug it for safety. Remove the filter. Then remove the 2 screws that hold the filter chute to the top of the machine. Then grab each side of the top from the rear and pull slightly forward to release the front and raise the top. Then remove the screws on the front and raise up the front after unplugging the lid switch. Then grab the idler and get the belt loose and lift the drum out as seen in my home movie:
Manual and more can be found HERE on my DIY page
Nov 24, 2012 | Maytag MED5600TQ Electric Dryer
Where is the reset button on my dryer?
on the back, lower section, remove the back cover and look for it, you will find it. Assuming it is not on the front, top, right out.
Aug 07, 2012 | Maytag MED5600TQ Electric Dryer
How to fix maytag med5600TQ0 dryer
You have not mentioned the fault on the dryer as it can be due to no power, a fault in power supply , no program a suspected controller and also no rotation , a possible motor , relay or controller fault.
Also if there is no heating check the continuity of the heater coils. if open heater is faulty , if not there no voltage from the controller.
Oct 01, 2011 | Maytag MED5600TQ Electric Dryer
DRYER WILL NOT RUN BUT HEATS UP ???
You probably have a broken belt and need to call the Maytag Repairman.
Dec 29, 2010 | Maytag MED5600TQ Electric Dryer
My lint trap is broken, how can I buy another one?
Here it is!
http://www.getmyfilter.com/33002970-Maytag-Dryer-Lint-Filter_p_228.html
Good luck and thank you for using FixYa!  We would sure appreciate a 4 "thumbs-up" rating for this FREE answer.  Happy holidays!
Dec 08, 2010 | Maytag MED5600TQ Electric Dryer
Need to remove front panel to get at belt. The drum isn't turning. Cant figure out how to do this! help
I think you need to take the top off, then the front panel will be easily seen, and you can start taking off the screws.
Jun 21, 2010 | Maytag MED5600TQ Electric Dryer
My Dryer makes a thumping sound when rotating even when rotated and there no power. MED6500TQ
your belt may need to be replaced. could have a crack or missing chunk out of it making it bump as it rides over the pully.
Apr 05, 2010 | Maytag MED5600TQ Electric Dryer
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
