Question about Whirlpool GHW9400 Front Load Washer
CUU replaced following F11 Code, now program light is flashing
We replaced the CCU in our Duet Washer but now the front program dial light is flashing and the program will not engage. Can you suggest what to do next?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F11 flashing?
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed.
May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 Code Showing
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
Courtesy:JSrock
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When trying to use the front load washer it flashes F11 and beeps an will not turn the washer on.
"F11" is a serial communications error between the Central Control Unit (CCU), the Motor Control Unit (MCU) and/or interconnecting wiring. The following link explains:
The first step in troubleshooting this problem is to UNPLUG the washer for at least 30 minutes to reset the CCU. This is the main "brain" of your washer. Sometimes these error codes are erroneous and can be corrected by resetting the main computer. If the error code reappears following a CCU reset, then you have a legitimate problem. Read through the link and let me know if you have any questions. I hope this helps you.
May 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Error Code F11
its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code F11 and the washer does not continue
"F11" is called a Serial Communications error. This commonly occurs when the Central Control Unit (CCU), which is the main computer, does not receive proper signals from the Motor Control Unit (MCU) for whatever reason. Before assuming you have a failed part, however, the manufacturer recommends unplugging the appliance for at least 30 miuntes to reset the CCU. Sometimes this is all that is required to correct momentary glitches. If the problem returns, review the following link for more information:
In many cases this problem cures itself by resetting the computer. However, more commonly, when it appaears as a reoccuring problem, the CCU fails. Read through the link thoroughly, however, and follow the recommended advice just to be sure. Hopefully, this will not require any replacement parts. I hope this helps you. Let me know if you require further assistance.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
