Question about EliteGroup Computers & Internet
P4vmm2 (v1.0a) no display
No video out but there is power
What drivers can use for my video and sound card? ESC P4VMM2
driver for motherboard ECS P4VMM2
On this page you are offered with driver for p4vmm2 motherboard existing in our database. Icons placed on the left of file name will prompt you in which format and in what language driver download ECS P4VMM2 motherboard are represented in this file.
If the needed file doesn't exist, therefore the desired driver is missed in our database. It can be ordered in the File Request section.
You can also try to find the appropriate driver for kindred motherboard ECS models by clicking on the links shown below.
  • http://www.fixdevice.com/drivers/motherboard/ecs/p4vmm2.html
  • http://www.driverstock.com/elitegroup-p4vmm2-driver-download/25-9-3830/index.html
Sep 20, 2011 | Computers & Internet
My p4vmm2 rev.8.1 has only 256mb memory card and 128mb video card, my question is what would be the maximum bytes for memory card and video card can i install. Offcourse the compatible hardware..tnx
Looks like the max is 2 x 184-pin DDR DIMM socket support up to 1 GB, which means you can get 2 512MB DDR266/200 2.5V DDR SDRAM chips.
as far as video cards, it will accept any AGP 4x or lower card. You could also put a PCI video card in it, but AGP is better.
Dec 28, 2010 | EliteGroup P4VMM2 V8.1 Motherboard
I want my display drver
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1704&areaid=2&LanID=0
thats the driver for the intergraded video on a ecs P4VMM2 motherboard
Driver Name : S3 ProSavage Display Driver P4M266_KM266-P
Nov 27, 2008 | Computers & Internet
VIDOE CARD PROB?
reseat the video card in the slot. then use the cmos reset jumper on the motherboard (when the power is off). if this doesn't fix the issue, then the card may not be compatible with the agp or pci-e slot that is on your motherboard. If this doesn't work (I am assuming your motherboard also has a default (onboard) vga out port - then go into the bios and set the primary display device to be the agp or pci-e slot.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Brand new geforce 6100 pm -m2
This is for the EliteGroup P4VMM2 motherboard. Please remove any newly added video card. One done boot the PC. Windows should load & function (Including video display). Yes?
Restart the PC & press the delete key every 2 seconds untill the bios menu loads. Opem the manual to page 33. Change the Primary Graphics Adapter from PCI to AGP. Save & exit the bios. The system will begian to restart. Press & hold the power button untill the PC shuts down. Unplug the power cord from the PC. Install the AGP card & connect any additional power to the video card if required. Double check all data & power connections for good fit before closing case. Re-connect the power cord & start up the PC. You should have display. Allow windows to finish loading & install the AGP software. Than update windows.
Who ever heard a single long beep. This means the video card may not be seated fully & or correctly. Remove the AGP card, blow out the AGP slot with canned air. Take some alcohol dripped onto a cotton swap. Clean the AGP's copper contacts & clean/wipe the copper within the AGP slot as best as possible. Allow time for alcohol to dry. Re-insert the AGP card, firmely & evenly.
Any more troubles? Please list the issue here. Need manual for the EliteGroup P4VMM2? Click on this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good Luck!
Mike
May 18, 2008 | EliteGroup P4VMM2 Motherboard
Elitegroup P4VMM2 ATX mainboard
You can't fix it. I'm afraid it's a dead board.
erch.
Mar 17, 2008 | EliteGroup P4VMM2 Motherboard
Domanda di supporto scheda video su P4VMM2
now this is the language which i cant understand! so if u can tell me in english den i might be helpful to u !
peace!
Nov 15, 2007 | EliteGroup P4VMM2 Motherboard
Please help me with my p4vmm2 motherboard
power off, then open case and find reset jumper on mobo, then actuate reset then return reset position then power up...any changes?
Jul 04, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
14 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
