Question about Dell 1110 Laser Printer
Red light, "jammed paper", will not print, loud buzzing noise, sounds broken...?
SOURCE: paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Posted on Jan 18, 2008
  • 3278 Answers
SOURCE: Will not print - for scann or print - makes the
Give this a try: Disconnect all the cables to the printer. Hold it upside down and shake it really hard for 30 seconds. This should clear anything stuck inside the printer.
Posted on Jul 01, 2009
micromend
  • 748 Answers
SOURCE: loud grinding noise. Paper only coming half way
Hi
Grinding noises indicate either gears that are self destructing or something is stuck inside. Take out the cartridge(s), remove the paper and all the plastic that comes off. Unplug the cables. Now lift the printer, turn upside down and shake. If there are broken gears a local repair shop might try to fix it but most stores refrain from this.
Posted on Aug 05, 2009
  • 8 Answers
SOURCE: Printer jams but no paper jamming. I have to pull
clean and check your paper pickup roller.may need cleaning and or the roller may need fixing or replacing.
Posted on Oct 16, 2009
caroldon
  • 17130 Answers
SOURCE: Whenever I go to print
It can be that the paper drawing mechanism of the roller and the geared drive has an issue, possible that the motor has a play with the roller out of alignment , producing a difference of gap in the roller settings. If so the paper will be drawn into in different lengths so as to jam with the uneven pulling.
Posted on Sep 28, 2010
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Whilst just starting ti print there was an unexpected noise form the printer, like loud clunk. Now it won't print - it says there is paper jam but there isn't. Press OK to clear jam, then it does...
Sounds like one of the gears has probably broken
check out the HP website for suitable alternatives .if your in the uk try http://h40059.www4.hp.com/uk/printers/ otherwise start at http://www.hp.com/
Sep 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
When I am printing, there is a loud noise. Like something is not rotating correctly. Everything prints good, but that noise is really loud. It seems to happen when it feeds paper.
Hello there,
If there is a loud and buzzing noise inside it, the encoder strip, or the one that guides teh cartridge must be dirty. this causes buzzing sounds and mis alignment.
another is the rollers having too much paper residue in it.
i would recommend for you to clean the rollers with a lint free cloth and some water (just to dampen it)
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
When I turn on my epson nx110 a loud constant, buzzing noise comes from my printer. I have found that is based in the part that lifts up not the base of the printer. In addition the on/off button is...
you may need to software reset you epson printer, some epson printer has a print counter, once you have used your allowable print, it goes into errors mode, flashing the on/off button light..check also for jamb paper inside..
Feb 09, 2011 | Office Equipment & Supplies
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam with out paper
This is almost certainly a broken latch on the right of the carriage - it should get pushed forward by the left back edge of the cartridge mechanism as it reaches the right side. There are other examples of this described in many similar posts on various sites - including some with photos. Try and find another psc all-in-one and look at it. I have the same problem, and have 'mended' the latch so that the paper error disappears and it prints, but I have not yet solved the loud clicking
Richard
Mar 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error light on stylus c62- printer makes loud buzzing
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Jan 27, 2009 | Epson Stylus C62 InkJet Printer
Loud whine/buzz/wail, nothing prints
Well your leader (lead head) could be jammed or off of its track. The leader should sit on a steel/aluminum rod and it should run under the front of the cartridge. If its gearings are out of sink you can get the cracking sounds you're describing and the whining probably the motor that powers the leader having no resistance and going way too fast for what it is supposed to do. I'd look for a broken sprocket or gear.
Aug 29, 2008 | Samsung ML 2010 Laser Printer
Dell 1110 Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
