Question about General Washing Machines
Lint trap Frigidaire washer
Where is the lint trap on a Frigidaire washwe crown seires
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: need to know how to clean lint trap and where is
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
Posted on Jun 23, 2009
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
  • 14 Answers
SOURCE: GE top load washer w/no lint trap leaves excessive lint
Are you sure there's no lint filter? For general advice on cleaning a washer lint filter, try eHow: washer lint.
Posted on Aug 09, 2010
  • 170 Answers
SOURCE: Is there a lint trap
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Posted on Mar 17, 2011
My whole house smells like rotten eggs when I run my washer. I have read it could be the lint trap. Where is the lint trap on the Frigidaire gallery front loader?
. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out
Aug 15, 2012 | Frigidaire ATF6000ES Front Load Washer
How do you service the lint trap on FRIGIDAIRE FRONT LOAD washer MODEL ATF6000FS1?
What are meaning by service? You can clean it out and even clean out the coin trap of the unit for regular maintenance.
Aug 09, 2012 | Frigidaire ATF6000ES Front Load Washer
How do you clean the lint catcher
if washer having difficulties draining the water, check out the DRAIN MOTOR PUMP , IT COULD BE CLOGGED with LINT & debris, locate at bottom side is a small motor where 2 hoses are connected , AJ
Nov 22, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Lint problem
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
Sep 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Lint filter/can't find
THERE SHOULD BE A TRAP DOOR EITHER RIGHT INSIDE THE FRONT DOOR OR ON THE TOP OF THE UNIT MORE LIKELY RIGHT INSIDE THE FRONT DOOR
May 29, 2009 | Frigidaire GLTF1670A Front Load Washer
Cleaning the lint trap of my Affinity washing machine
no lint trap...the best you can do is give it a hot wash bleach with a cold rinse,,,onthejob
Dec 25, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Washing Machines Logo
44 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
