Question about NEC NP216 Projector
NEC NP216 projector won't display
Beeps three times on start up and won't display
3 Suggested Answers
  • 3278 Answers
SOURCE: My NEC VT660K wont power up.
Hello.
Some suggestions from NEC support:
Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on.
• Ensure that the lamp cover or lamp housing is installed correctly.
• Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move the projector to a cooler location.
Hope this helps.
Posted on Nov 05, 2009
AJIN G
  • 6694 Answers
SOURCE: NEC NP905 Project lamp light
hi,
To reset the lamp hour of you projector Press the HELP on the remote control for 10 seconds.
ok
Posted on Jul 28, 2011
Como desarmar un mini split carrier
You tried three notebooks, but did they have the same video adapters? Try a notebook with a different video adapter. i would say your video adapter isn't good enough to put out a dual display. you might need to get a laptop with a better video card
Jan 23, 2014 | NEC Office Equipment & Supplies
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
My NEC lt30 is smoking after installing a new bulb. There is a rectangular, hollow plastic piece that seems to be touching the bulb and smoldering. Is there supposed to be metal over this? Is it part of...
First, stop using the unit IMMEDIATELY. Is the replacement a genuine NEC bulb or knock-off? If it's genuine, they'll replace it. We have had issues with the cement used in the knock-offs in several different projectors. They all work fine at first, but the cement will break-down very quickly, and will let the actual 'capsule' move-around inside the lamp module. The reason I'm serious about not using it, is that we had one capsule slide backwards and melt-into the wiring. That caused the $200 ballast board to fail.
Aug 31, 2011 | NEC LT30 Multimedia Projector
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
Hello.
Hope this helps.
Nov 05, 2009 | NEC VT660K Multimedia Projector
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Office Equipment & Supplies
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
NEC NP216 Projector Logo
48 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
