Question about Rowenta Ultra Professional DM991 Iron
Parts breakdown for Rowenta Model DM 991G steam iron
geokohler
  • 304 Answers
SOURCE: Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Posted on Jul 24, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
  • 12 Answers
SOURCE: Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Posted on Apr 26, 2009
  • 240 Answers
SOURCE: Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Posted on Jun 11, 2009
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free
This will work for sure.
Aug 21, 2010 | Rowenta Professional DE880 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Jun 13, 2008 | Rowenta Professional DX8800 Iron
Rowenta Ultra Professional DM991 Iron Logo
111 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
