Question about Singer Sewing Machines
Singer GL220 dont know how to thread my machine
Does anyone know or own an old sewing machine like this one ? I have no manual, don't know if I have threaded it properly and won't sew. apparently so I've been told, it does sew.
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Posted on Mar 06, 2010
Does anyone have a picture of directions for threading my White Sewing Machine Model 1477
Hi Iris. Singer owns most of White Sewing Machine company's manuals now. The are available for download. Here is the link
http://www.singerco.com/uploads/download/1083_white-1477,1488,1499-x.pdf
Sep 19, 2012 | White Sewing Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Singer 8280 sewing machine tension won't increase
Make sure your needle and tread match your project. There simply isn't such a thing as a "universal needle." Also try lengthening your stitch. Heavier fabrics typically need a slightly longer stitch. Upon commencing to sew always grasp the 2 threads and slightly pull as you begin your seam.
I assume your garage sale find has a manual. Be sure your bobbin is unspooling in the correct direction. If it didn't come with a manual.. http://www.singerco.com/uploads/download/430_8280_es.pdf
Good luck.
Jul 04, 2012 | Singer 8280 Mechanical Sewing Machine
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
I have a brand new 4423 that is frustrating me so much I'm tempted to return it and buy something else. It will not sew a seam without having "birdnesting" underneath. It's horrible!! ...
Take it back while its under warranty and ask the dealer to thread up and sew on it; this way you can establish if it is a faulty machine or if its some other variable causing it. Certainly if you are an experienced sewer and have used other Singers, then you would know if you've done it correctly and your instincts tell you the machine is faulty so I'd suggest you take it back to the store.
Oct 03, 2011 | Singer 4423 Sewing Machine
I have a singer sewing machine model # 758 touch n sew and I cannot find how to set the bobbin thread tention. The thread bunches up under the bottom plate and adjusting the upper thread tention does not...
Hi, welcome to fixya, maybe I can be of some help
I checked on singer website & they have a free downloadable instruction manual in PDF form just follow the these steps
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 758 )& click search
the second one is free
Sep 10, 2011 | Singer Sewing Machines
I have a Totally Me Singer Sewing Machine and I don't have an instruction manual. I don't know how to thread the needle on the sewing machine. If you can help this would be great !
Try this link: http://www.singerco.com/accessories/instruction-manuals Type model no. in the search field and press Search. You'll be able to choose to pay or download for free! Good luck!
Aug 15, 2011 | Singer Zig Zag 727198 Sewing Machine
Very old singer Model 400w2T serial # w1263253 How to thread this machine? PLease
you might want to give this place a try - they carry manuals for really old machines -
Sewingmachine221sale
if they don't have a manual, the guy might be able to give you some advice on how to try anyway....
Jul 30, 2011 | Singer Sewing Machines
I am trying to use a singer featherweight II but I can't figure out how to thread the machine no manual
Is this a very old machine because the manual I"ve located doesn' look like the image on Fixya.
Try this link http://www.singerco.com/uploads/download/997_white-117.-kenmore-x.pdf
Singer have various model manuals downloadable, you just need to search them at their website page http://www.singerco.com/accessories/instruction-manuals/search
Trust this helps you out.
If you don't resolve the issue and this is a vintage machine, then there is some good user groups such as Vintage Singers under Yahoo where enthusiasts share info on their old machines. Good to lurk though or go through old threads first as there is often someone else who has asked similar question in the past. There may also be manuals in their files so have a dig around.
Jun 06, 2011 | Singer Featherweight II 117
Sewing Machines Logo
43 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
