Question about Bushnell Optics
What model is a Bushnell 9x40 763942 and where can I get turret covers?
I have a Bushnell Rifle Scope 763942. Where can I get parts?
  • 7 Answers
SOURCE: scope for ruger 10/22 carbine
Google SWFA ......they sell about 20 different brands of riflescopes, with pix, desriptions and prices. It's a good source for info, even if you decide to buy one of the same scopes at Walmart. Check out the Bushnell Trophy, Nikon Prostaff, and Tasco scopes, in particular.
Also, there is a website I belong to, originally started just for the Ruger 10/22 owners/fans. You can visit it and join for free at - www.RimfireCentral.com
We have a great bunch of guys and gals there, who can help you with questions on ANY type rimfire rifle. I'm sure you will love this site.
Posted on Feb 09, 2009
  • 12 Answers
SOURCE: how to zero Bushnell 3-9x40 scope rifle
http://www.bushnell.com/products/scopes/riflescopes/doa-riflescopes/
Go to this link & you will be able to zero it. If you lower the angle of telescope you will be targetting farther. vice versa. aqeelhafeez@hotmail.com
Posted on Mar 26, 2010
agent91
  • 2100 Answers
SOURCE: Where can I get a sun shade for a Bushnell Banner
Check out this website. Hope it helps.
http://www.bushnell.com/products/scopes/riflescopes/instruction-manuals/
Posted on May 04, 2010
  • 243 Answers
this is a good guide:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Posted on May 31, 2010
SOURCE: PARTS FOR A TASCO RIFLE SCOPE
I need an adjustment cap for a Tasco Golden Antler 3x9. Where or how do I get one.
Posted on Aug 30, 2010
Exploded diagram
You don't actually adjust cross hairs, you adjust point of impact. You do this using the turrets located near the center of the scope. the top one will adjust height, the r hand one will adjust windage.
Feb 21, 2014 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Crosshair are turning to right
Are the turrets also turning to the right? If not, the crosshair ring has broken loose inside your scope, if so, you need to correct issues with your mounting system.
Oct 07, 2010 | Bushnell Banner 6-18x50 Ao Rifle Scope...
Elevation turret stripped out. Entire turrent turns with no adjustment . Turret came off when reinstalling cover. Was not forcing cover tight and had just started to tighten.
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
Sep 05, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
My rifle scope is maxed to the left is there way to recenter adj screw
it sounds like your saying the turret is wound over fully to the left?
if so the scope mount is at fult...the only way to pull the cross over to the right is to pack out the scope mount with old film on the right side of the scope this will make the scope shoot futher to the right
Nov 11, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
To adjust the vertical on a Bushnell Banner scope, which way do I turn the screw and how much. I am 6 inches high
The top turret should be the one you need. You should see an U or D with an arrow pointing in one direction or another. Your scope should move the point of impact 1/4 inch at 100 yards for each click. Moving the adjustment 24 clicks in the down direction should fix you up if you are shooting at 100 yards. The movement will be linear for other distances.
Sep 29, 2009 | Bushnell Banner 3-9x40 Riffle Scope, Matte...
I need covers for the adjustment turrets on a 6x24 B&L scope. The number on the scope is V001051.Can you provide them and what is the cost?
most likely you will have to send the scope in to have this taken care of to contact bushnells customer service at 800-423-3537. press option 1.the age of the scope necessitates having the scope to match parts.
Aug 24, 2009 | Bushnell Optics
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
May 09, 2009 | MAG Simmons 22Mag Rifle Scope 4X 32...
Optics Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
