I have a Sony TA FB940R (HiFi stereo amp) and the volume control reverts to the silent position, ie it rols back and won't stay put. As if a damper has been damaged or stopped working. Can you suggest a fix please, any help much appreciated
  • u2_jeff Oct 25, 2008
    Thanks very much, and for posting so quick
    Thanks you are a real pro
  • 10,594 Answers
If you are tech guy then follow below technical instructions to fix your Amp problem.
Amp has motorized volume control and motor drive circuit has problem so motor rotates just one side (ends up volume) Below picture shows how is motor board and what drive IC is to power the volume motor.
You need to check voltages at pins and replace bad IC.
It is very simple circuit and easy to repair.
Good luck.
Posted on Oct 25, 2008
  • Shahid Electronics
    Shahid Electronics Oct 25, 2008
    How do you rate this solution?
How can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
On the iPod, (or the Doc) is a 3,5 mm socket, where the earphone or speakers go in. On your Amplifier, are two gulp entrys, called line input. Just use (perhaps you still have to buy one) a cable from 3,5 mm Stereo, to 2 tulip plugs to connect both. Then when playing, test the volume you should put the iPod top, so your amp can handle he signal and the sound through the speakers sounds good. Then use the volume knob on the amp to fine adjust.
The amp was build in a time there were no iPods, so don't expect an USB entry o that one.
Cable you need:
Sep 16, 2014 | Audio Players & Recorders
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
No sound records sony dcrtrv530
I reviewed the owners manual to your camera.
On page 126 it says this:
1)The stereo tape is played back with HIFI sound set to 2 in the menu settings.
Set it to STEREO (see page 79)
2) The volume is turned to a minumum.
Press Volume + (see page 27)
3) Audio Mix is set to ST2 side in the menu settings.
Adjust the audio mix (see page 79)
If one of those 3 options doesn't work, try using an 8mm tape head cleaner.
Jun 15, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
Sony TA-AX301 Amp looses left speakers
many times this problem is the result of dust and or dirt that has collected in your control pots.ie.volume,balance etc....the solution is usually to take the amp apart to get to the pots and clean them out with tuners cleaner or some such product...a quick fix would be to rapidly move the knobs side to side or press the buttons or toggle the switches as fast as you can in hopes of clearing some of the particles from the affected area...
Feb 03, 2008 | Audio Players & Recorders
542 people viewed this question
 Grubhead
Grubhead
