Question about Kenwood KDC-7024 CD Player
Unit keeps opening and shutting
When powered on, all the unit will do is open for about 5 seconds, briefly show the words 'Code Off', and then close for about 5 seconds, and then continually repeat this cycle. Any thoughts?
  • Des Kill Aug 17, 2006
    Thanks for that Jexx, any idea where I can find a copy of the service manual?
    Scholar:
  • 148 Answers
Yes, in fact, I believe the ribbon cable is bad. A new one can be ordered from www.kenwoodparts.com Hope that helps! Any assistance with taking the unit apart will best be found in the service manual!
Posted on Aug 17, 2006
My BOSCH Axxis 24201UC washing machine displays "E:16" (which means "Door not closed properly") all the time, no matter what, and is inoperable
Check that the door switch is closing when you close the door with the latch mechanism. Unit will be dead unless the switch is closed.
Sep 20, 2017 | Bosch Washing Machines
Tip
How to format the internal Hard Drive
To format the HD in the DRC8030N, do the following. Power off the unit (so you only get the clock on the LCD) and then press and hold the PLAY and OPEN/CLOSE buttons for about 5-6 seconds or until you get the FORMATING word in the LCD. It will do this for about 5 seconds and voila, you are back in business. Keep in mind that by doing the following you will loose all your saved info like saved titles and such. So if you have a saved TV show that you really do not want to erase, then record it to a DVD Disk first
on Apr 16, 2010 | RCA DRC8030N
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
A fault or error has occurred. Code 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Apr 22, 2011 | Xerox WorkCentre PRO 128 Copier
ERROR CODE 010-327
Hope it helps!
Apr 07, 2011 | Xerox CopyCentre C128 Black and White...
What are the carrier 8000ts led error codes?
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Oct 05, 2010 | Heating & Cooling
How do you unlock the tray for the panasonic sc-bt200 .when i press the button to insert a disc it says the word lock and it won"t open
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
Feb 15, 2010 | Panasonic SC-BT200 Home Theater Systems....
My drc8030n says I am out of space
To format the HD in the DRC8030N, do the following. Power off the unit (so you only get the clock on the LCD) and then press and hold the PLAY and OPEN/CLOSE buttons for about 5-6 seconds or until you get the FORMATING word in the LCD. It will do this for about 5 seconds and voila, you are back in business. Keep in mind that by doing the following you will loose all your saved info like saved titles and such. So if you have a saved TV show that you really do not want to erase, then record it to a DVD Disk first. I hope this helps
Jan 11, 2009 | RCA DRC8030N
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Kenwood KDC-7024 CD Player Logo
74 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
