Question about KitchenAid Dryers
What year was kitchenaid gas dryer KGYE660W manufactured
3 Suggested Answers
  • 68 Answers
SOURCE: KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Posted on Mar 22, 2010
SOURCE: need service manual for KitchenAid
So do I.
Posted on Feb 24, 2011
Kitchenaid gas dryer model # kgye800swh1 starts, but does not heatup
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 04, 2011 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
I have a kitchenaid dryer that worked fine all day and then my last load to be dryed no heat not at all
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | KitchenAid KGYS750LQ Gas Dryer
The dryer isnt heating up to dry clothes
If it's a electric dryer I would suspect the high limit fuse and thermostat on the heater element housing or the heater element itself. Most of these problems are caused by a restricted house vent. They should be cleaned every 3-4 years. If it's a gas dryer, I would suspect a bad ignitor or gas valve coil.
Oct 10, 2010 | KitchenAid Dryers
No heat when gas dryer is turned on. Ten years old has never presented any problems.smesyates@aol.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 12, 2010 | KitchenAid KGYS850LT Gas Dryer
A friend gave me one kitchenaid dryer , i don't understand. canI use eletric power and propane, or only propane. I don't have the propane pipes conections, can you please help me understand it?
Your propane dryer only dries with propanr. The electrical cord is for the motor that turns the dryer and for the controls. If you don't have gas piped into your house then your gas dryer is useless. Either get an electric dryer or pipe gas into the house. If you have Natural gas in your home, then you need to get a conversion kit to make your dryer run on Natural gas.
Jun 17, 2010 | KitchenAid KHEV01RSS Dryer
Mar 22, 2010 | KitchenAid Dryers
I am trying to find out how old my kitchenaid dryer is the model is YKEYE860WW2 Ser:9JH37361
I believe a Kitchenaid with a "J" in the second position of the serial number would have been manufactured in 1999.
Mar 18, 2009 | KitchenAid KAWS850L Dryer
Open Questions:
Dryers Logo
65 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
