Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable runs continuously
My GE JVM1540DM1WW over the range microwave is having issues.
The turn table runs continuously and the surface light and fan will not turn off once activated from the control panel.
Turning the breaker on and off resets the issue, but it resumes (tt turning) after first use. If we don't activate the fan or light from the control panel we don't have the issue (ie if the fan turns off because the stove is on, it will still turn off automatically). Also, unplugging the 10 pin connector from the smart board resets the issue but then it resumes after first use.
Where should I put my money? New smart board, new panel control, or something else?
    Top Expert:
  • GE Master
  • 23,659 Answers
Door switch is my first option.
Posted on Mar 26, 2017
5 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: my microwave turntable is scrubing
The floor will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would then leave the door open to let it dry untouched overnight.
You didn't mention your oven's brand or model, but it may be that the wheels on the turntable support are worn or there may grease built up in the axles.
Or you may need a new turntable support.
If you need to order a new one, please reply back with your brand and model number so we can help point you to the proper distributor.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: ge spacemakerxl microwave, jmv1850
Your primary interlock (bottom door switch) is bad, or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 18, 2009
sonicboomele
  • 1557 Answers
SOURCE: I have a GE JVM1340WW02 spacemaker XL microwave.
not a fuse problem itsounds like its the ic controlon the front panel crt board
Posted on Apr 20, 2010
ercupa190
  • 12223 Answers
SOURCE: GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Posted on Oct 11, 2012
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave JVM1631 turn table not working. How to fix it?
The motor underneath the turntable may have failed. Removal of the access cover will expose the motor for continuity checking
Aug 17, 2013 | GE JVM1631 Microwave Oven
Turn table will not trun
The turntable motor is defective and needs to be replaced.
Mar 05, 2011 | GE Profile Spacemaker Over-the-Range...
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks coming from underneath turntable.
check for black spot on support for turn table and floor of unit, sand them back to the metal serface and paint if cavity is not stainless steel, if turn table is not turning replace the motor as this could cause this issue as well.
Feb 04, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
83 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
