Question about Ricoh FT3713 Copier
Toner overflow the toner sticks on the drum and copies are black and paper sheets won't come out and it stack up on the releasing roller.
  • acejrcpqn Oct 26, 2008
    right the paper get stuck on the fuser unit.is the blade be replaced when the toner always overflow?
  • Ricoh Master
  • 2,794 Answers
Could be the cleaning blade isn't working on the drum.  Is the paper getting stuck on the fuser unit?
Posted on Oct 25, 2008
  • Tim Babcock
    Tim Babcock Oct 27, 2008
    The cleaning blade is replaced when the drum is replaced.  It could be that the blade is worn out before the drum went out.
    There could be a few things going on with the fuser.  everything from a bad pawl to the rollers needing to be cleaned or replaced.
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
I loaded a lined sheet of notebook paper into our printer tray to have something print on it. It came up with the message that there was a paper jam and to remove the paper tray and toner cartridge. I...
The only way a paper jam could affect your print quality is if it were actually stuck in the toner/drum cartridge area. I would remove the drum unit and then take the toner cartridge out of the drum unit and make sure there is no paper in either of the 2 units. The only other possibility would be that the sheet of paper wrapped around the fuser roller. This is the area just before the paper exits the machine. This would usually cause the print/toner on the copy to rub off or not be fully "fused" onto the page.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother MFC-8460N All-In-One Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Hi, I have a Ricoh 1224c, color copies come out with a blurred or waterfall effect on about the first half inch of the leading edge of the copy, but the black copies are ok. The next 1 1/2 inches roughly...
The Colour toner more small and he does not disappear the blade a peelings, you it is necessary to check the magnetic hand on colour cartridge. If hand unevenly covers the magnetic gross to adjust the дозирующее blade. Clean the gross, insert the sheet of paper between dose and gross and release the bolts an dose blades, press the blade to paper aside gross magnetic, afterwards bolt the bolt. Extract the sheet. Clean all from the remainder of the toner. Check the blade a peelings drum if evaporation during stop main by breaker exists on drum, change rakel. The Period of rakel's work is measured by period of the work photo drum, beside 10 thousand sheets. Such effect more often exists from wear-out of rakel. Remind, black toner has grain more so he leaves the rakel. The Colour toner small and its clear requires new rakel.Udachi. fault has not an electronic reason. This mechanics.
Oct 06, 2009 | Ricoh Office Equipment & Supplies
My printer does not pick up the paper sheets from the paper tray.When I took paper sheet in to slot it works.
Well - I don't know if this will solve it (since there could be many causes) but it worked for me.
1 - Remove Paper Tray
2 - look at rubber rollers in printer undercarriage
3 - carefully remove "rubber bands" from roller
4 - turn rubber bands inside out and carefully return to rollers
5 - remove toner cartridge
6 - remove print drum assembly
7 - return printer drum assembly and toner cartridge
the roller trick helps the printer pick up paper
the toner/print drum trick helps reseat the inner workings of the printer correcting any misalignments that impede paper flow
Jun 09, 2009 | Lexmark E232 Laser Printer
Black stripe across copy
The orange roller is probably contaminated from toner that is sticking partly to the photodrum in the cartridge. That roller is likely made of silicone rubber (heatproof) that presses the paper against the fuser roller to 'fix' the toner to the sheet.
I suggest replacing the cartridge and cleaning whatever is accessible before you put the new cartridge in.
May 04, 2009 | Minolta Office Equipment & Supplies
Paper jam on initial feed
It sounds to me like your pickup rollers are worn. You should order a new set and replace them. That should solve your paper jam issue.
Feb 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Black marks on my paper when I print
Replace the toner with new one. because It's problem of toner drum (It's in blue or green colour).
Dec 08, 2008 | HP Color LaserJet 3500 Printer
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
