Question about Onkyo TX-DS575 Receiver
Where to plug the rc cables for audio?
Flat panels have audio output and receiver don't,how can i have audio?
  • jazvic May 11, 2010
    which brand is you "Flat panel" couse all that i know have audio out!
    Thanks
    President:
  • 2,992 Answers
Outputs from a source connect to inputs on the receiver. Use an RCA cable to connect the flat screen's audio output jacks to the input jacks you want to use on the receiver. Select that input on the receiver and you will have the audio from the flat screen set.
Posted on Jan 28, 2009
Where do I plug HDMI cable to a soundbar. I have 3 HDMI inputs but no output
Hello. Your Mitsubishi doesn't support HDMI ARC (Audio Receiver Channel). You will have to use the AVR or the Digital Audio output to connect your sound bar. Sorry.
Aug 13, 2015 | Mitsubishi WD-60737 60 in. HDTV
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
What is a toslink cable.i have a new coax i bought today with rc male plugs on each end is this the same.im in Australia. Thanks
A toslink is an optical audio cable. Not an rca (red and white plugs) cable. U probably have a digital audio cable....if it has one rc male at each end. Usually denoted by an orange color. It doesn't matter where u are in the world. Hope that helps.
Dec 06, 2014 | Televison & Video
I HAVE A SANYO LCD TV dp42d24. wANT TO ENHANCE SOUND WITH EXTERNAL SPEAKERS. THE RED/WHITE ON THE TV BACK SAYS audio input. i WANT AUDIO OUTPUT
There's probably a digital audio output you can use if you have a digital receiver. If you don't have a digital receiver you can take the audio out from the cable box or satellite box. Since I have an old analog receiver it's the way I connect my equipment. I use a hdmi cable for the TV so it frees up the rca output jacks on my cable box. Works great.
Aug 25, 2014 | Televison & Video
No sound with dvd connection
Check connections for loose contacts, and whether the audio in has been selected to connect the RC cables, and whether the output selected at DVD end is correct. Check for jammed buttons of volume or mute on remotes of both.
Aug 04, 2012 | Dell W4201C 42 in. Plasma HDTV
I have a 42 inch maxent but i dont know where to plug my cable cord because i have a comcast box and theres no where in the t.v to plug my cable cord
If your comcast box has video (yellow), audio R (Red), audio L (White) out, just connect RC cables to the input of the TV at video, audio-in RC Jacks. If your comcast box has only RF out, buy one RF to audio-video converter and then connect these to the TV.
Jul 11, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
GE audio/video switch AV93294 has what appears to be a adapter port on front , no voltage given. Says audio output. Please explain
As the label says, it's an audio output. The audio from whichever source you have selected appears at that jack so you can plug in something like a pair of headphones or the cable to a wireless headphone transmitter. If you don't have anything to connect there, don't worry about it. It's a convenience, but you don't need to use it.
Aug 14, 2011 | Audio Players & Recorders
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Onkyo TX-DS575 Receiver Logo
204 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
