Question about Solis Maestro Electric Burr Grinder
Baratza Maestro Classic coffee grinder
After a big party my grinder stopped working.
How do I open it up? There are no screws so they probably use tabs to hold the cover on. I tried using cardboard in the four slots on the bottom but that didn't release them. Any recommendations?
  • cogneuro2003 Jan 19, 2009
    mine is making bad grinding noises as if something is stuck in it.
    how do you open the device to get at the mechanics?
4 Suggested Answers
SOURCE: Switch Broke
I don't know about the switch going inside but you can contact baratza and they will send you a new knob that won't fall off for free.
Posted on Apr 01, 2009
  • 1089 Answers
SOURCE: grinds coffee too coarse
Hi Sounds like you have a broken grind adjustment ring. You should contact Baratza and see if you can get a replacement. 877-701-2021 8:00am to 5:00 PST Monday thru Friday.
Posted on Jun 06, 2009
  • 1089 Answers
SOURCE: My Solis Maestro grinds but produces only about
Hi
I would say that your grind adjustment ring is broken inside and needs to be replaced.
Contact Baratza at 877-701-2021 Mon. thru Fri. 8:00 to 5:00
They should be able to help.
Posted on Nov 14, 2009
SOURCE: how to adjust new baratza maestro plus
I, just adjusted the the solis 167; first remove the Bean container by turning counter clockwise and the pull straight up) then remove the timer dialer (time/quantity control), then remove the cover by lifting the locking tabs (2 slots each side) with a flat screw driver. Once you removed the cover. Pull straight up the the white ring with the metal cup. Now you see a dark ring which is clicked on the with unit. When you look under the ring you an see little holes all along the white unit (that's important because you need to mark your old position). After marking the thr ring on the white unit, pull off the the dark ring by slowly pulling the ring outwards just on 2 places on the ring where there an small hole in the ring (there are 4 holes). When you turn the ring you will see 2 nobs, now place back the ring with the nobs 2 places further(clockwise) than the old position. You have just adjusted the grinding control! Place back all parts in reversed order. To place back the Bean container you must be aware that there are 2 black nobs in the machine and 2(different sizes!) on the container, they must be placed in a cross.
I trust you will hav succes. Don't turn to far at once because you have now modified the machine and this could damage it! I will assume no responsibillity for damages! Masta NL
Posted on Apr 02, 2010
Timer knob is broken, I need a replacement
Hi Contact Baratza at 877-701-2021 They should be able to help.
Feb 06, 2010 | Solis Maestro Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Hi
Nov 14, 2009 | Coffee Makers & Espresso Machines
Poor grinding
Hi
Try calling Baratza at 877 701 2021. They should be able to help.
Aug 28, 2009 | Solis Maestro Electric Burr Grinder
Grinds coffee too coarse
Jan 13, 2009 | Solis Maestro Electric Burr Grinder
Switch Broke
Nov 25, 2008 | Baratza Maestro Plus (G385) Electric Burr...
Solis Maestro Plus: Grinding Adjustment does not move and can not take out Grinding Ring
Hi
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Jul 12, 2008 | Solis Maestro G385 Electric Burr Grinder
Solis Maestro Electric Burr Grinder Logo
113 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Mike Cairns
Mike Cairns
Richard Roth
Richard Roth
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
