Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Aceleration It starts OK but after some time the speed control (aceleration) does not work. It has 2 screws that can not be adjust with any tool, someone told me that it required a special tool for this, in other words you can not adjust the carburator.
  • 47 Answers
Are they red and white if so they pop off to access the screws
Posted on Feb 05, 2009
Mercedes 300E starting problems
If the problem is only on cold start check cold start injector, it cuts out after the engine worms up .a faulty thermostat can delay worm up.
May 11, 2014 | Cars & Trucks
S&S motor with CV carburetor; Start and run idle great but have problem with aceleration . Carburetor cleaning, aceleration pumps is good, gas is ok.
Hi Dennis, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Aug 27, 2013 | Harley Davidson Motorcycles
My beattle glx start light EPC. start engine but dont aceleration. I buy module (computer and configuration) but no aceleration.
new computer needs programming---------ask majicmech@aol.com-------pero primero hav u done tuneup on ignition and fuel -clean throttle body idle control
Dec 08, 2011 | 2001 Volkswagen Beetle
My honda dazzler has starting problem and acceleration problem. can you tell me whats the problem in my bike
The starting problem could be your ignition coil needs replaces
The aceleration could be your throttle cable is damage or needs re-adjusting
Aug 12, 2011 | Honda Senda DRD Racing 50R Motorcycles
Engine fluctuates at idle speed and during aceleration
suggest you replace idle control sensor,,hope this helps!!!
Aug 16, 2010 | 1997 Ford Thunderbird LX
At the begining of aceleration car hesitates and shuddering after that drives well, but any suddenly aceleration does it again
check fuel supply and or filter must be clogged engine runs short of fuel supply/ check throttle body attached to the intake manifold your ISC (idle speed control sensor) or TPS (throttle position sensor) must be malfunctioning..
Apr 06, 2010 | 2000 Toyota RAV4
Slow aceleration
has the fuel filter ben change?see if you catlike convertors are pluged.or try you mass air flow senser. it could be bad. good luck
May 31, 2009 | 1993 Saturn SW1
The aceleration of the motor is up and down evre time i stop
have you tried an engine idle relearn?
start car don't touch a thing, encluding brake. Let idle for 2 fan cycles. and see how it works from there.
Mar 12, 2009 | 1992 Honda Civic
Problem aceleration
1. chenk the gas pedal see if the screw and the stake behinfd the pedal has problem.
2.check the cable, maybe the angle is not right. you have to check the cable behind the pedal and also the end part which connect to the fuel controler. either fuel injection or carburetor
Hope this can help you to solve the problem.
Jun 18, 2008 | 2000 Toyota Tundra
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
269 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
