Question about Intel Motherboard
I cant see anything on the screen
HI I ve assembled my new msi mother board but when i switch on i cant see anything on the screen. the "on" led lights are on the fan is scooling the monitor is Ok. ive connected everythihng properly. the processor is ok with another computer. Anybody with a an idea?? Ishoreal
  • Ishoreal Monnathebe Aug 24, 2006
    Hi
    Ola Habib. Thanks to giv me the light. I've actually found where the problem is. Ive got intergrated Video card on motherboard but the blank screen was the missing 4 pin plug of power supply there was 20 pin only. seems both are needed to power up.
    Shap
Was lost the driver Microstar MS6182 Ver. 1... pleas tell me how can i get a free download for that motherboard driver, thanks..........
Posted on Jul 19, 2008
    Problem Solver:
  • 19 Answers
First of all tell me u listen booting sound or not? NOw put out ur mobo properly and placed on non metel sheet. Now on ur motherboard.Recently avail products are usally senstive U cheak ur supply also .
Posted on Jan 09, 2008
Look and see if L16 popped off right by where the heatsink clips on the cpu. That's what happened to mine. Powers on but no display or loading. HD lights on for about 10 seconds then shuts off.
Posted on Aug 02, 2007
  • 432 Answers
Good Job! I hope everything works out for you. Thank You for using FixYa.
Posted on Jul 01, 2007
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Getting all four led lights on at the same time and hard disk light on constantly have a MSI K7N2GL mother board and nvidia gforce mx intergrated gpu
Hi, you can download a manual here:
http://www.msi.com/product/mb/K7N2G.html#/?div=Manual
My guess is that your harddrive has died.
Try to change the harddrive out with a new one
and make a new installation.
Or it simply runs out of memory.
Could also be overheating.
Sep 11, 2011 | MSI K7N2G-L Motherboard
I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
Mar 03, 2011 | MSI 865GM2-LS Motherboard
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
I need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=558
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Mike
Apr 03, 2008 | Computers & Internet
That mother board want reboot
lets say it like this...you have assambled..on  table...motherboard..,processor,memory hard drive...all conected to teh monitor (you have video on  board) and to the power suply.
If you get the power in a board with  a damaged processor...the board receive energy and ,depending of the problems of the processor..youl see a blu screen on monitor..or just hear some pcspeaker specific sounds..ussualy the msi mainboards come with a special feature called D bracket..it has some leds on it and indicates your problems...
however..if you have other problems than blue screen or sounds..and the board is totally silent..well it is a board fault...and here..the reasons of malfunctioning are a lot..
Feb 02, 2008 | MSI RC410M-L Motherboard
New mother board
sounds like either you have button connections wrong or you need to set bios defaults
Nov 12, 2007 | MSI PM8M-V Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
MSI KT3 Ultra2-R Motherboard
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=497
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
Intel Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
