Question about LG Washing Machines
WM2377CW Tromm ultra capacity
Electrical board
2 Suggested Answers
  • 16 Answers
SOURCE: LE error
try using a-fresh its should help you out.
Posted on Nov 03, 2008
Hot do i change capacitor on board please?
Make sure that the capacitor is discharged and there is no power to board. Un solder the cap on both ends from the board and replace with another known working capacitor of same capacity and voltage. The value on the replacement can be a little higher but in no circumstances should the capacity or voltage be lower than the original.
Mar 06, 2016 | GRACO INC Ultra Max Ii 695 High Boy Paint...
Lg 4.0 tromm ultra washer will not work. Lights come on but washer does nothing
Sounds like the main PWB board inside the machine is faulty.
Nov 09, 2015 | LG Washing Machines
Lg tromm washing machine
Is this the actual and complete model number from the ID tag on the unit?
Apr 16, 2014 | Washing Machines
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer powers on but turns off a second or two later. I don't see any error code since it turns off right awat. What can be the problem?
Try using another outlet. Connect an extension cord to another outlet away from the room you are in and see if that will resolve the issue. If it does, you will need to call an electrician to resolve the electrical outlet problem. If the machine continues to shut off, you will need to have the control board on the washer replaced.
Good luck
Jun 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE error
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
