Question about HP OfficeJet Office Equipment & Supplies
Error 388 on officejet 8600
Won't fax
  • 16 Answers
SOURCE: error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Posted on Jan 05, 2008
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
  • 4 Answers
SOURCE: fax not working Error 388
I used to have the same problem anytime I tried to use the fax. Drove me crazy. The problem for me was that whenever HP software updated it corrupted the installed software and I had to reinstall the program.
I finally ended up copying the files from the install disk on to the hard drive so I could find it quickly when I needed it and HP would repair itself using the hd installation files.
You might also check the back of your printer to make sure that none of the cords are lose or the usb isn't loose from the pc. This will cause it to have problems with the handshake. I found especially during warm weather that they tended to get loose because of expansion.
Hope this helps...
Posted on Aug 27, 2008
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
Tualiapz
  • 80 Answers
SOURCE: Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
Posted on May 29, 2009
HP Officejet 8600 Plus won't align printheads
TRY UNPLUGGING IT FOR A MINUTE OR SO... AND TRY AGAIN.
Dec 02, 2014 | HP Officejet Pro 8600 e-All-in-One -...
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
Keep getting error code 388* when im faxing something
Pls do the following
Error Code:
388
Solution
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp4225 do not sent or receive fax messages, error 388*
hiii
well this error generally arises when there is too much of disturbance in the line.It may going away with time.And if it doesn't then u must retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Sep 03, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Solution
Solution
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 4315
HP Support Web page
<http://tinyurl.com/lbwcwd>
Error Code:
Solution
Apr 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
367 people viewed this question
Seeker5211
Seeker5211
