Question about Irons
Leaking Bosch TDA4632 Sensixx B3
Soon after buying the Bosch TDA4632 Sensixx B3 as a present for my wife it started leaking of water from the bottom of the iron as well some brown material. She has managed with it and has only recently told me - is there anything we can do ? - thank you
SOURCE: bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
Posted on Jul 07, 2009
SOURCE: i have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Posted on Feb 13, 2011
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
arjay_00023
  • 28 Answers
SOURCE: I have a Bosch Sensixx
check Ac cord for bad contact, more caused cutoff wire inside the cord, then try, if not ok,, try to check wiring inside the unit for loss connections.
Posted on Aug 12, 2011
My bosch sensixx B22L makes every 5 to 10 min a roaring noice
My iron is leaking water from the plate when using it on the steam why is this?
Jan 02, 2013 | Irons
Too hot to handle spits water from sides Bosch sensixx B10L
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Dec 22, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Sep 26, 2012 | Bosch sensixx TDA 8333 Iron
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx b3 instruction manual
I have a Bosch sensixx b3 iron I have Lost the manual and need to de scale it
Jan 28, 2012 | Irons
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 | Irons
I have a Bosch Sensixx Comfort Power iron. Not had a lot of use as I live alone! One day it worked perfectly the next time I went to use it didnt work. Checked fuse.
Aug 11, 2011 | Bosch sensixx TDA 8333 Iron
I have a Bosch Steam Generator Sensixx B25L. It has suddenly started leaking water from the back out of the plate. This only happens when the steam button is pressed and the handlegets very hot with it. ...
Jul 27, 2011 | Irons
Bosh sensixx B25L iron spraying brown water
Feb 22, 2010 | Bosch Irons
Irons Logo
99 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
