Factory restore hp dv4-1125nr
Factory restore
Restore factory settings programs step
On newer (Vista and up) to restore to factory press F11 at HP splash screen this will put you factory restore mode ( not earlier restore point) then follow the on screen instructions including backup option of files if you haven't done this if no backup is needed choose to continue without backup and this will bring your HP laptop back to factory, out of the box, condition. You will have to reinstall programs of choice and update adobe free products like Adobe Flash and Reader and all of the windows OS updates good luck
Dec 12, 2013 | HP Compaq nc6400 Notebook
Need too restore to factory
The HP Mini laptop comes with either the Windows 7 or Windows Vista operating system.
You can restore the HP Mini to its factory settings using the laptop's recovery partition.
Restoring the HP Mini to its original factory settings will get rid of hard to eliminate viruses on the laptop's hard drive.
A factory restoration is also a good way to get rid of older files still stored on the computer that you no longer need and start with a clean slate.
Windows Vista
Click "Start" in the lower-left corner of your HP Mini Windows Vista home screen, then type "Recovery" into the Search box at the bottom of the Start menu. Click "Recovery Manager" in the list of options that appears above the Search box. The HP Recovery Manager will open. Click "Advanced Options" and then "System Recovery." Click "Next." Your HP Mini will restart. The HP Recovery Manager will open up automatically after the restart is complete. Click "System Recovery," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process begins. This could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista. Windows 7
Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager." Click "Recovery Manager" again to open the HP Recovery Manager program. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista.
b>
Feb 04, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Restore to factory settings
If you did not create a set of factory restore cd\dvds when you purchased the computer, then you can hit the F11 key during post (while the HP screen is displayed) to boot to the restore partition. You will want to chose restore to factory settings, this will cause the computer to ask are you sure a couple of times before proceding.
Hope this helps
Jan 08, 2012 | HP Computers & Internet
How to cold reset the hp lj m1120 printer
No cold reset for this model.
Only Restore default Option.
Restore the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
1. On the product control panel, press Setup.
2. Use the arrow buttons to select Service, and then press OK.
3. Use the arrow buttons to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 08, 2011 | HP Office Equipment & Supplies
My HP mini netbook has a virus and need to factory restore it. first, how do i factory restore it? second, the computer is my roommates computer and she forgot the admistrator password on it so whenever i...
Are you certain you need to do the factory restore?
In order to do the factory restore you need to have a restore DVD or an uninfected partition on the hard-drive which contains the original install files
If you can boot in safe mode, run Windows restore and be sure to select a restore point/date at which you are certain the virus was not on the PC.
Press F8 on startup before the blue password box appears and you get the option to boot in safe mode.
Oct 14, 2010 | HP Mini 1000 Netbook
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Feb 20, 2010 | Computers & Internet
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
Cannot get dial tone to send a fax
try to reset your printer to factory setting
purchased your HP PSC. Choosing to restore your factory defaults restores
all settings, except date information.
You can perform this process from the front panel only.
1 Press Setup.
2 Press 5, then press 3.
This selects Maintenance, and then selects Restore Factory Defaults.
The factory default settings are restored.
and you can find the manual at this link
http://h10032.www1.hp.com/ctg/Manual/bpu05064.pdf
Jul 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
