Question about Kitchen Appliances - Others
WOLF LG300 fryer pilot light
WOLF WLG300 fryer pilot light will not stay lit. Is it the overheat thermostat or thermocouple?
bigg t
  • 640 Answers
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Posted on Nov 11, 2007
bigg t
  • 640 Answers
SOURCE: vulcan 1gr45 deep fryer
The thermopile is bad.You can contact your local hobart service center for the part number.Its a cheap part and easy to put on,any questions let me know.
Posted on Dec 03, 2007
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Posted on Feb 13, 2008
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
SOURCE: Imperial fryer
I am looking for a new tank for an imperial deep fryer #im63739 mine is leaking any thing i can do
Posted on Jul 09, 2009
PILOT LIGHT WONT STAY LIT i CHANGED THERMOPILE
pilot flame to small
over temp safety thermostat trip
dirty connection points
thermocouple fail not the same as thermopile fail
thermopile drives the gas valve.700MV
thermocouple drives the pilot light safety system.30MV
gas valve magnet fail
check the above for any faults
Jan 19, 2016 | Kitchen Appliances - Others
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Pilot does not stay lit
clean pilot light first , you may need to change thermopile or thermocouple see what mille volts you get from thermopile need 600mille volts
Mar 27, 2012 | Star 630FD Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Pilot won't stay lit
If a standing pilot won't stay lit, the usual cause is a bad thermocouple. The thermocouple is a safety device with a probe that is kept heated by the pilot flame and produces an electric signal. Wires from the thermocouple connect to the main gas valve. If the thermocouple fails, the main valve shuts off gas to both the pilot and main burner. When you try to re-light the pilot, it goes out again as soon as you release the pilot button on the valve.
A new thermocouple is only $10 or so, and it's pretty easy to change. There are a number of how-to sites and videos showing how to change the thermocouple in gas furnaces and water heaters, and the process is similar in commercial ovens and fryers. Once you see what the thermocouple looks like and how it's installed in some other appliances, you'll be able to identify it in your fryer and see how to change it. That should get your frying again.
Dec 28, 2010 | Imperial IFS40 Deep Fryer
My pilot light will not stay lit. I have replaced the thermocouple and still will not stay lit. Can the valve be bad?
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Nov 25, 2010 | Frymaster Dean SR42G Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Feb 10, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
74 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
