Question about Dell Dimension 4600 PC Desktop
Dell 4600 usb ports not working
Hi, my 3 yr old dell 4600,s usb ports have all stopped working, i have a wireless keynoard and mouse, and i replaced these thinking it was those at first, but by plugging in a memory stick that flashes when being read, i now know that none of the usb ports are any good. i have tried a powered hub, but still no joy
any ideas
thanks
chris
  • polski1681 Oct 25, 2008
    hi buddy
    thanks for trying, but because the ports dont work i cant utilise the mouse at all, should i try a non usb connected one ?
    thanks
  • polski1681 Oct 26, 2008
    i have connected a non wireless keyboard, thats ok, but i now need to connect a hard wired non usb mouse.when i connect the powered hub, it now brings a baloon saying that an un recognised connection has been made. i tried start>control pannel, but theres no device manager ? any ideas much appreciated.
    Sergeant:
    Champion:
  • 275 Answers
Do one thing disconnect all the devices connected to the usb and if possible use a ps2 mouse to do the step i am going to tell you or if u can use the keyboard that would be fine ...
go to device manager and uninstall all that is under universal serial bus ... remove everything that says root hub and than restart the system
Posted on Oct 31, 2008
    Sergeant:
  • 306 Answers
Have you gone to Start>Control Panel>Device Manager to see if there are any yellow exclamation marks in front of the usb devices?
Posted on Oct 25, 2008
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
Mouse and keyboard stop working when windows starts
have you checked out if they work in safe mode?
if they work in safe mood means they are working
which keyboard mouse are you using usb? ps2? or wireless?
Apr 20, 2014 | Dell Dimension 4600 PC Desktop
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
I've had this wireless mouse for 3 months (microsoft wireless mobile mouse 4000). it just stopped working. the battery is fresh (the red light is still on) and the transmitter is still firmly in the usb...
When you replace the Battery on a Wireless Mouse you have to link the Mouse again with your USB receiver. There should be a Button on the bottom of the Mouse that could be marked, Reset, or Link or something similar. Just turn on your Mouse and hold this Button for a few second until the USB receiver finds the signal.
Jan 05, 2011 | Microsoft Wireless Optical Notebook Mouse...
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
USB ports appear to not be working. Any clues?
Go to setup turn on the USB 1.1
The USB port is turned off for security reasons;
You may consider adding a 4 port USB 2.0 adaptor card my server has Both I use the onboard USB 1.1 for external hard drive and mouse
Nov 19, 2009 | Dell PowerEdge 4600 Server
Where do hook up wireless. I have dell desk top.
Hi and welcome to FixYa,
Almost always, wireless mouse makes use of the USB port to connect its base/receiver. Depending on the exact model of the Dell desktop, there would normally be USB ports at the rear of the computer. Some others have 2 USB ports at the front or side.
Good luck and thank you for asking FixYa.
Oct 22, 2009 | HP Wireless Optical Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My wireless keyboard and mouse stopped working on my computer
Upgrade the Bios and make all the critical updates of your Hardware from the Dell site. Check also that the bluetooth is enabled through bios. Try also to make all the updates to your OS.
Mar 20, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
1,058 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
