Question about Kitchen Ranges
Sakura 747 range hood has stopped working
Fan motors AND light have stopped working. Is there a circuit breaker inside the actual unit?
SOURCE: Range element does not work
Model KERC500Y Standing in front of stove the Left front
burner won't heat.
Posted on Mar 24, 2009
  • 44 Answers
SOURCE: Whirpool Range suddenly tripping the circuit breaker
It could be one of the elements is shorting out causing the breaker to trip. Try using one burner at a time to see which one causes the short.
Posted on Aug 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Posted on Aug 23, 2009
dmftrucker
  • 1922 Answers
SOURCE: My electric range is tripping the circuit breaker
unplug the unit and see if maybe you have a problem in the breaker/supply line from the house panel, otherwise does it work fine?,there also may be a bare or shorted wire in the unit itself
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Posted on Sep 02, 2009
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
I have Sakura kitchen range hood model #c R706, R727 and Want to know how ro chaneg teh bulb. Thanks
I found all the part I needed for my Sakura range hood at http://www.rangehoodking.com/ they had everything I needed. of cos that light bulb too!
Dec 31, 2010 | Kitchen Ranges
Suddenly the light and the fan quit . Is there a reset
the only "reset" is the circuit breaker.... if they both suddenly quit working, there is no power to the hood at all.... if the breaker/fuse at the box is good, then the hot wire has slipped out of the connection.... not an easy way to trace it. all you can do is work backwards, starting at the power box up inside the hood. if all those connections are tight (power supply to unit's wires) then it's in the wall, attic, or under the floor.... no fun.
Nov 26, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
