Question about Husqvarna Garden
2003 55 Rancher to much compression
TO much compression, difficult to pull start
5 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: Will not start after setting 4 years
the 455 rancher chain saw is a two cycle motor.Two cycle motors do not have valves in them.Stihl in another matter.Take the muffle off the saw and look to see what the piston rings look like.If they are brownish in color then you need to thak the cylinder head off and clean the piston and rings. usualy it is carbon and old oil.Hogwash works very well in this situation.Use only your hand to rub the hogwash around the piston.Even thought this doesn't sound like your problem.The trouble will be in the car. itself.The gas that was in the carb is on longer.You will need to replace the diaphram and gaskets in the carb.Once you do this the fuel will get to the cylinder.and the saw will fire.Make sure that you ran the oil mixture on the heavy side for the first tank of fuel.This will oil the bearings down in side the crank case.they way be gummed up from sitting for so long.After the first tank of fuel is used up then use regular mixture.
Posted on Feb 11, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Husky 55 Rancher, was sawing a tree and
Yes. this checks both. Change the plug first <$5 plug >$50 coil.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Ignition module gap
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
dontbother10
  • 2220 Answers
SOURCE: Husqavarna rancher 55 repairs
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston.
• I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it).
• Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  1. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
  • 95 Answers
SOURCE: I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Posted on Mar 17, 2011
I have a Husqvarna 55 Rancher and it is very hard to pull start--it does not have a compression relief--once it starts it works fine
The saw may have built up carbon on the piston or exhaust port. This would cause the starter rope to be difficult to pull. Have the secondary compression checked. It should be between 130 - 155 psi.
Nov 21, 2016 | Husqvarna Garden
How do i fix the electric start
Honda Rancher 350 Shift ' eBay
www.ebay.com/bhp/honda-rancher-350-shift
eBayHONDA All-Terrain Vehicle (ATV) TRX350FE Rancher 4x4 ES 2002 329. ... HONDASHIFTER TRX 350 RANCHER 2000-2006 ALL MANUAL SHIFT MODELS NEW (Fits: More than ... This handlebar switch assembly will fit:2006 trx350fm. ... 2000-2003Honda TRX 350 TRX350 Rancher Electric Shift Start Kill Light Switch.
Clymer Manuals Honda TRX350 Rancher Repair Shop ...
? 1:57
https://www.youtube.com/watch?v=wbGzGZXTEDU
Feb 20, 2009 - Uploaded by ClymerManuals
Clymer Manuals Honda TRX350 Rancher 2000-2006 repairmanual ... 2001 2002 2003 2004 2005 2006 Honda TRX Rancher ATV quad to be a ... alternator, ignition system, starter, relay, diode, electric shift system, ... how do i replace the choke cable on my 2002 honda fourtrak 350 from the carb? thanks.
How do i fix the electric start - Fixya
www.fixya.com/support/t26063336-fix_electric_start
50 mins ago - how do i fix the electric start when pull started the head lights are dim - FMF ... Question about FMF ATV HONDA RANCHER 350 2000-2006 ...
honda rancher 350 troubleshooting Questions & Answers .
Jan 21, 2016 | FMF ATV HONDA RANCHER 350 2000-2006...
My 2006 Honda rancher 350 just quit running while I was driving it. will still turn over but wont start why?
Take fuel cap off to make sure it is getting air to fuel tank. Check fuel valve to make sure it is on. Drain carb with screw on bottom of carb to check for water. Pull spark plug to make sure it is firing.
Feb 15, 2015 | Honda 2006 FourTrax Rancher AT
No spark on Huskvarna Rancher 55 and Easy Start issue
Compression release! Is that not normally applicable on compressors? One normally has to open the compressor tank valve before being able to start the compressor motor so that the motor does not have to be started "on-load". Is what you are looking for (the Smart Start as you mentioned) not maybe a basic clutch assembly between motor and chain drive assembly that has failed?
Aug 28, 2014 | Garden
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher that is difficult to impossible to start. If I get it started and stop it it won't start back. when it starts it runs fine. I took the plug out and cranked the engine and there was a...
my 455 did this also I went and bought a new gas filter new gas and mix. try this you might have some water in your gas,also add some sea foam additive to your gas mixture just about a table spoon to 2.5 gallons of gas
Feb 23, 2010 | Husqvarna Garden
Will not start
I
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
These flood easily and are very difficult to start once that has occurred.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Sep 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Jan 18, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
