Question about Exercise & Fitness
How do I fix my crosstrainer, magnetic resistance has stopped working
When you change the resistance dial up or down, nothing happens, There is now no resistance. How can I fix this?
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Posted on Jan 20, 2013
    Top Expert:
  • 12,223 Answers
Dear Sir:
Please do the following step:
1 Connect your machine to its power source. If your elliptical machine runs on electricity, plug it in. If your elliptical machine requires batteries, put the proper batteries in the console. Usually this means placing two or four D-size batteries inside the display console.
  • 2 Start pedaling to turn on the display.
  • 3 Choose the pre-set program you will complete. Follow the prompts and choose the level of resistance or difficulty that you want. This will determine the adjustment of the magnet. For most machines, such as the Precor elliptical machines, you will use up and down arrows to set the resistance. If your machine does not include pre-set programs, you can skip this step and go directly to Step 4 instead.
  • 4 Use the appropriate buttons on the console to adjust the magnet. Usually there are up and down arrows to adjust the magnet. If you want the resistance to be higher, press the up arrow. If you want less resistance, or easier pedaling, press the down arrow.
  • 5 Continue to adjust the magnet as needed throughout your workout by pressing the appropriate up and down arrows on your machine. sincerely.God bless you.
  • ernesto cuadra
  • managua, nicaragua. c.a.
  • Posted on Feb 15, 2012
    2 Suggested Answers
    maxtreadmill
    • 832 Answers
    SOURCE: Proform Crosstrainer 5.0 Treadmill
    ICON CALIBRATION INSTRUCTIONS- INCLINE
    1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
    2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
    3) Press either incline key and the incline will calibrate automatically.
    4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
    Posted on Jul 16, 2010
    2000 Ford F250 Disel: Nothing works on the panel for the a/c heater. The fan does nothing when you change speed there is nothing that comes out, there isnt any heat or cool, and when you turn the dial...
    Pull the wires from the blower. Throw 12 volts and a ground to it(red is B+). If it comes on, it is good. Replace the controller. If it was the relay, some sort of blower speed would have happened. There are other wires to check, but you would have to loose other things to go this direction. Like accessory and ignition.
    Jan 10, 2015 | Ford Cars & Trucks
    No tension on proform 215 csx upright bike
    tention belt or spring is broken. buy a new bike its not worth fixing.
    Jul 24, 2013 | Cars & Trucks
    Life fitness crosstrainer 9500 HR just shut down few second after start
    see the video and fix it. This happen because the lack of maintenance schedule.God bless you
    Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
    Dishwasher won't start
    its the timer in the dial replace it and it will work fine yes its worth fixing
    Dec 03, 2012 | Kenmore Dishwashers
    My garage door will only open half way. It appears to be getting stuck when it is opening.
    If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
    Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
    Resistance on elliptical acting weird
    1) tight the bolts tension for magnet and clean very well. and proof..if the fail
    2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
    God bless you
    Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
    Incline won't shut off
    Please RUN The software calibration for diagnose, troubleshooting and fix it.
    download your inst.manual from www.iconservice.com or www.fitness.manualsonline.com and proceed according
    God bless you
    Jul 18, 2012 | Icon Proform 560 Crosstrainer Treadmill
    Pro-Form 500 LE resistance is reversed
    The problem I am encountering is that the resistance doesn't seem to change. Whether I am on 1, 5, or 10 it seems the same. Any ideas for ME?
    Mar 14, 2012 | Exercise & Fitness
    How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
    That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
    If you hold down the metering mode button, the command dial will change the exposure metering mode.
    If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
    If you hold down the release mode button, the command dial will change the release mode.
    If you hold down the AF button, the command dial will change the autofocus mode.
    If you hold down the QUAL button, the command dial will change the image storage mode.
    If you hold down the ISO button, the command dial will change the ISO.
    If you hold down the WB button, the command dial will change the white balance setting.
    If you're looking at the menus, the command dial will navigate the menu.
    If you're reviewing pictures, the command dial will move to the previous or next picture.
    Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
    Jun 29, 2011 | Cameras
    My fax machine will not send. When I dial the number it does nothing. This just happened and I have faxed on it before.
    No polling capability at remote side.If th number you dial is a Personal Web Server it only supports 10 concurrent connections. HP Toptools usually uses 3 connections for each user, so after three users invoke Toptools, PWS starts to slow down. Rapidly changing tabs can result in too many connections temporarily.
    Dec 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
    Exercise & Fitness Logo
    2,557 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
